![]() Join Date: Apr 2011
Fuel system plumbing
I'm curious...do I need to install a 1-way check valve on the pressure (feed) side of the fuel rail? I'm not sure how much would readily fall back into the tank (I'm using an in-tank pump)
Is it more of a convenience or a necessity? Thanks!
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
meowMEOWmeowMEOW
Re: Fuel system plumbing
just seems like one more thing that can leak, clog, or fail. If my truck sits for a WHILE, I might have to key on for 2-3 seconds before cranking; however I do that anyway to hear the dbw throttle body cycle (just a habit, since i used to have problems with it).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
The in-tank pump has a check valve built-in.
![]() Join Date: Nov 2007
What Clinbarger says. My LS2 will hold full pressure for a couple of weeks normally.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Cool, much appreciated guys!
OK another question -
What did you guys use for plumbing the fuel lines to the sender? Do the fuel rail quick connects work on the sender as well?
