>Question about Timing<
I recently had the heads rebuild on my son's '81 Sierra 1500. After much tweaking and tuning, I have replaced the carb with a re-manufactured unit, and have been messing with the timing. I don't think the mechanical advance is working. When I set the timing with truck in park, vacuum disconnected and port plugged I do not get any advance when I throttle it. When I hook up the vacuum it is only getting about a 10* curve. I realize the spec says to set initial at 6 degrees, I have always added ~ 2 degrees per 1,000 ft elevation (we live at 4,200 ft) so I have it at 12* initial and total is only 22*~ 23*....
Is that enough total advance? Should I just lock? |
#2 | |
Re: >>Question about Timing<<
#3 | |
No, that is not enough advance. You need to pull that distributor out and get it working properly. It will make a huge difference in how it runs and the fuel mileage.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#4 | |
Thanks, I found this in the FAQ, makes perfect sence.. http://67-72chevytrucks.com/vboard/s...d.php?t=290498[/URL] |
