10-14-2011, 02:32 PM | #1 |
Dropmember and turning
So I ordered a drop member for my blazer and I was wondering for those you guys running one is, since the crossmember narrows the track width can you make turns with the tire and wheel still tucked in the fender.
I am running a 15x7 wheel with a 235/60/15 tire with like a 3.5" backspacing. Later, on I'd like to run a 20x8 wheel with a 255/35/20 and a 4.5" backspacing. However, I don't want to have to air the truck up to the point it looks like a donk when I drive down the road. |
10-14-2011, 02:44 PM | #2 |
A guy with a truck
Re: Dropmember and turning
You will be able to turn lock-to-lock at ride height (~6"), tires/whels tucked, without airing up 'donk style'. The trade off here is that the rack & pinion doesn't turn as tight as your current box, so the wheels don't contact the fenders...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-14-2011, 02:50 PM | #3 | |
When I drove it down the block with my son this is where we had the ride height. Last edited by Rochlow; 10-14-2011 at 03:00 PM. |
10-14-2011, 06:04 PM | #4 |
Back needs to be lower
Posted via Mobile Device |
10-14-2011, 06:39 PM | #5 |
10-14-2011, 09:55 PM | #6 |
Looks great! Kinda makes me want to give up on my shortbox project and use all the goodies on my blazer instead
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
10-15-2011, 12:39 AM | #7 |
10-15-2011, 01:48 AM | #8 | |
10-15-2011, 08:34 AM | #9 |
Very nice!!! I am building a blazer now. Where did you mount your air tanks and what size are they?
10-15-2011, 08:44 AM | #10 |
3 gallon under the body behind the rear wheel.
10-18-2011, 01:30 PM | #11 |
Village Idiot....
This is where I'm driving at the moment, you have to be careful turning sharp corners or it will "touch" the fender. I have driven it lower but at this height I can drive it without to many worries. Hope this helps you....
http://67-72chevytrucks.com/vboard/s...351837&page=44 post 1092
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
10-18-2011, 01:40 PM | #12 | |
10-18-2011, 03:13 PM | #13 | |
needs more $$$
1970 2wd Blazer |
10-18-2011, 05:50 PM | #14 | |
Village Idiot....
It rides awesome! I don't know the PSI, I'm using AccuAir and the system doesn't use gauges.
