10-14-2011, 08:05 PM | #1 |
Muncie 4 speed in a 65 c10
Was wondering how difficult would it be to replace the old 3 speed manual trans for a m21 or m22 To go behind a 350? WHich trans would be better the m21 or m22
THANX jason |
10-14-2011, 08:16 PM | #2 |
Re: Muncie 4 speed in a 65 c10
i just parted out a 64 that had a m21 with 350 setup i kept all the stuff but sold the trans let me know if you need any parts the only thing i noticed was that they used a bellhousing that matched out trucks the old cast iron one that fits right to the existing crossmember
10-14-2011, 08:26 PM | #3 |
It'll bolt right in with the correct shifter.
10-14-2011, 09:29 PM | #4 |
"Where were you in '62?"
I got some info on Muncie 4 speeds here bud if you wanna check'em out.
http://67-72chevytrucks.com/vboard/s...d.php?t=390542
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
10-14-2011, 09:55 PM | #5 |
M21--helical cut gears ....quiet, not quite as strong as M22 but still very capable trans
M22--straight cut gears (rock crusher)....much like a cam gear drive, very strong but noisy. |
10-15-2011, 09:35 AM | #6 |
Hollister, CA.
When I installed the Muncie in my old truck .... I realized it was the EXACT same length as the stock 3-speed, which I believe was a MUncie as well.
Not soon enough though, as I went ahead and removed the stock bellhousing crossmember and fabbed up another one for the tail end. Didnt have too !! The driveline slid right in as well. As for shifter, I ordered one from Summit for an early Nova....this placed the shifter in the correct spot for the bench seat. Worked out really well.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-15-2011, 07:52 PM | #7 | |
Senior Enthusiast
In a street application, having the gear ratios too close together results in frequently skipping either 2nd or 3rd gear because they aren’t far enough apart to make it worth going through all four. A wide ratio transmission provides much more flexibility for a street engine. From another perspective however, I’m sorry I don’t have an M22 in my truck. I love the howl and whine they emit, which isn’t available from any other transmission. Here’s a link regarding Muncie gear ratios: http://www.5speeds.com/muncie2.htm |
10-15-2011, 08:26 PM | #8 |
How would a Super T-10 compare in strength to the M-21 or M-22. Seemed like we were always looking for a Rock Crusher or a T-10 when we were building the cars back in the day
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-15-2011, 08:36 PM | #9 |
Suscribed! Cheifrocka, do you have a part number on that summit shifter?
10-15-2011, 09:10 PM | #10 | |
Senior Enthusiast
The only disappointment I have with the Super T10 is it isn’t as obnoxious as the M22 in the sounds effects department. I really love the M22 transmission racket. Here’s another thread that discussing the comparison between the M22 and Super T10 (T10S): http://www.hotrodders.com/forum/rich...10-181381.html |
10-15-2011, 09:14 PM | #11 |
Enjoy your truck
Jason, I have had an M-21 in my '63, with 327, for the last 20+ years.
Lots of fun and no problems. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
10-15-2011, 09:34 PM | #12 |
Midwest Muncie...is producing brand new M22's....for sale right now, (not cheap)....but claim to be the strongest 4 speed ever made (up to 800ft. lbs.), close and wide ratio.
NEW Auto Gear Super Case Muncie M22 Rock-Crusher, Street/Strip 4-Speed New Heavy Duty Direct Replacement and Strongest M22′s Made With Muncie Auto Gear Super Case and Strongest M22 Close Ratio or Wide Ratio Gears. 26 spline input and large 32 spline output shaft. AG Steel Mid-Plate. Super Tail. OEM Side Cover. A great Super Heavy Duty Rock Crusher M22 for your Camaro, Nova, Chevelle, Corvette or other GM car. Close Ratio = 2.20-1st, 1.64-2nd, 1.28-3rd, 4th direct. Wide Ratio = 2.52-1st, 1.88-2nd, 1.46-3rd, 4th direct. Built for big HP car’s up to 800Ft Lbs of torque. Up-Grade to a New Auto Gear Roller Side Cover for $150 (normal $185 Up-Grade). |
10-15-2011, 09:45 PM | #13 |
