Old 10-14-2011, 08:27 PM   #1
dbcox
dbcox's Avatar
swapped sm 465 Mech linkage to hydraulic
I just completed this swap on my 86 fullsize blazer. All i could find was bits and pieces of info on this swap. Everything i used was stock of the shelf parts except for the bracket I made for the Slave cylinder. This isnt a tech write up just info i gathered and how i did mine so maybe to help others. i am going to try and post some pics.
1. The holes in the firewall are indeed there, even a center hole dimple so you dont even have to guess at the center for the master cylinder. I got it Oreillys.
2. picture shows master and resivoir mounted
3. just some pics of the bracket.
The resivoir, hose,cap came from LMC. The hose was way cheaper thru them
The master cylinder and slave came from Oreilys.
Oh, and that is the mechanical clutch , clutch arm.
I dont have pics of under the dash, its prettty straight foward. I am temp using a bolt thru the clutch pedal till i find a piece of rod to weld in.
The master cylinder rod misses the clutch pedal by about three inches and the retun spring hookup needs to be cut off the clutch pedal.
Hope some of this info and pics help help as i am not a typing tech about explaining things. All in all a very easy swap to do, and alot easier to mash the clutch in
www.lubedealer.com/dbcox
ZO#1568374
dbcox is offline   Reply With Quote
Old 10-14-2011, 09:49 PM   #2
rcbildr
rcbildr's Avatar
Re: swapped sm 465 Mech linkage to hydraulic
Do you have any deflection on the slave cylinder bracket? I've been thinking about doing something similar with my 83 camaro...the mechanical on it really sucks.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-14-2011, 10:20 PM   #3
madcow75
madcow75's Avatar
dimples in the firewall I do not see any in my 76 I have been looking at mine wondering and contemplating were to cut my holes. I also am going hydraulic on my sm465. Want to get the holes right.
madcow75 is offline   Reply With Quote
Old 10-14-2011, 10:34 PM   #4
russgt
russgt's Avatar
Nice and clean setup. How much money do you think the swap cost?
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-14-2011, 10:59 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Nice job taming the beast.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-15-2011, 12:21 AM   #6
dbcox
dbcox's Avatar
thanks.
No there is no movement in the plate. i used 1/4 thick plate. i had it laying around.
total cost prolly just over $100. Like i said the slave and master cylinder was the cheapest at oreilys and the hose, resivoir and cap was cheaper thru LMC.
Clean the fire wall really good, they are hard to find as u can see mine is an offroad only from the dirt. If you see in my pic the dianond shape edge is the same shape as the master. the dimples shoukld be there kinda diaganal .
ZO#1568374
Old 11-08-2011, 01:39 AM   #7
rcbildr
rcbildr's Avatar
Could you post up some measurements (if you have a template or something) for the slave cylinder bracket? I'm going to be doing something similar on my camaro here soon and could use all the help I can get. Thanks!!!
My Projects:
1978 Camaro Z28
Old 12-06-2011, 03:52 PM   #8
Adam5432002
Tag for parts list. Great converson.......
Adam5432002 is offline   Reply With Quote
Old 12-23-2011, 07:21 AM   #9
argonaut
argonaut's Avatar
Tagged also. Great writeup, as I'm planning on doing something similar on my 66 K10. Do you know what the fitting sizes are on the fittings for the master and slave cylinders?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-23-2011, 10:29 PM   #10
rcbildr
rcbildr's Avatar
I don't have the measurements, but if they are anything like the fittings on the clutch hydraulics for my camaro the fittings are held in with a roll pin.
My Projects:
1978 Camaro Z28
