Old 10-15-2011, 01:36 AM   #1
hbaublit
hbaublit's Avatar
Is it a good deal?
I was looking for a frame with a stepnotch already welded in and came along this one. I am not sure what the going rate is for frames. This one is boxed and z'ed. The guy wants 200 for it. I haven't seen it in person yet, but here are some pics. When I do go look at it, what should I make sure to look at?
1970 Chevy Step
hbaublit is offline   Reply With Quote
Old 10-15-2011, 01:46 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Is it a good deal?
200 is a great deal but I question the a-arms and wonder if it's square or not...
Also, the rear notch probably could use some cross bracing....
also, what motor was it set up for? Looks like big block mounts (?) which you'd have to change if you're going sbc...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-15-2011, 02:06 AM   #3
hbaublit
hbaublit's Avatar
I will have to ask on the mounts, didn't even think about that. Bracing is defiantly the plan for the notch.
As for squareness, I am assuming that you are talking where it's got the goofy square tubing welded up?
1970 Chevy Step
Old 10-15-2011, 03:06 AM   #4
Mike Bradbury
Mike Bradbury's Avatar
looks like the entire cross member is welded to the frame, that might make it kind of difficult if you need to change any component.
A arms need to go, they are too sketchy looking.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 10-15-2011, 03:12 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
Wondering if the frame is square itself....measure front to rear diagonally and from the front crossmember ends to the frame rails and from the rear of the notches to the rear frame rail....
Old 10-15-2011, 03:26 AM   #6
OARNGESI
OARNGESI's Avatar
that looks a little sketchy id start with a stock frame even if its more
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-15-2011, 08:36 AM   #7
eurospec1
eurospec1's Avatar
Ya, i would not trust someone elses fab work for something like this, you would be much better off getting a stock frame and doing the work yourself
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 10-15-2011, 08:45 AM   #8
mbgmike
I would pass on this. Don't like commenting on others work however I would pass on this without hesitation.
Run Forrest Run
mbgmike is offline   Reply With Quote
Old 10-15-2011, 08:49 AM   #9
OJ1988
Just a car guy
OJ1988's Avatar
I would take that straight to the recycler.
There is a reason why its not under a truck.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-15-2011, 09:54 AM   #10
cdowns
cdowns's Avatar
yep recycler is the place for that abortion
Old 10-15-2011, 10:59 AM   #11
bcutt
bcutt's Avatar
That frame is only worth is weight in scrap...pass.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 10-15-2011, 11:06 AM   #12
YBNORML
YBNORML's Avatar
Think about it, someone put a ton of time and money into that frame. And now they are basically giving it away? Why? Probably cause it's junk. I agree with the earlier posts, this kind of work is better handled by yourself or farmed out to someone reputable. Not purchased second hand where you know nothing about what was done!
Run away, I would
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-15-2011, 01:16 PM   #13
Flint70step
Flint70step's Avatar
Run away, I would
What he said......if it was a good frame the PO would still be using it and not dumping it for $200.Keep searching or DIY.Be good
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 10-15-2011, 03:46 PM   #14
weircc
weircc's Avatar
these guys said it best!! too much time in that not to be using my friend!!
1971 rs camaro under the knife ls3 6 speed swap
1970 396 big block shorty fleet 67 clone
2010 rs/ss camaro
weircc is offline   Reply With Quote
Old 10-15-2011, 03:56 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
while I agree with the above comments....check to see if the spindles are drop spindles and in good shape. Plus, the frame looks fully boxed. If it was square i'd buy it for the frame, spindles, and brakes, and notch, (and possibly crossmember after checking out how it works with steering...and cut off/scrap the rest...
(spindles/brakes are worth over 200 if it's drop spindles)
Old 10-15-2011, 04:01 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
Looks like hammer marks on this side of the step notch.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-15-2011, 04:25 PM   #17
big_al_71
big_al_71's Avatar
Pass!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-15-2011, 08:33 PM   #18
hbaublit
hbaublit's Avatar
This is exactly why I posted on here first. I knew it's the place to get honest answers. Thanks everybody.
1970 Chevy Step
