Old 10-15-2011, 10:02 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Unhappy New windshield and now my glove box is a swimming pool!
Just had a new windshield put in my Cheyenne20 last week and after a heavy rain storm the other day, the glove box was full of water!
I've had this truck for many years and never had any water in the glove before this.
Prior to the windshield, I welded in a donor top section as it was rotted and resealed the gutter on top so it can't be from that area.
Any ideas on where this is coming from? I suspect it must be getting behind the gasket somehow. ???? Floor was perfectly dry so it's only in the glove area.
HELP!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-15-2011, 11:11 AM   #2
Indyuke
Re: New windshield and now my glove box is a swimming pool!
Yeah, it's getting through the gasket. I had that happen to me with an LMC gasket. I pulled that puppy out within several months and put a precision gasket in, then ran around the edges with a micro thin bead of the best caulking/sealant I could find. Not even a drop comes through now.
Indyuke is offline   Reply With Quote
Old 10-15-2011, 11:19 AM   #3
shawno72
C/10 junkie
shawno72's Avatar
I had the same problem when I replaced the rear window seal. I fixed it real good. Sold the truck. lol
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-15-2011, 01:09 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I suspect it is leaking in around the gasket and ends up in the corner of the dash on the inside. There is a small drain hole in the dash there and if it runs through the drain hole it will run down the side of the glove box liner and right into the glove box via the seam where the liner is put together. Whenever I have a liner out or put a new one in I seal that seam with sealer, then if it does happen to leak it doesn't fill the glove box with water.
LockDoc
Leon
Old 10-15-2011, 01:17 PM   #5
The factory used sealer on the body flange as well as glass to rubber.
Old 10-15-2011, 01:19 PM   #6
rustyrodknocker
look for any ripples in the new gasket. I had this problem with an oversized gasket. I had two new gaskets side by side. One was three inches longer than the other. Went with the short that time, would have been perfect if it was an inch longer. Rubber is my #1 frustration with the old trucks. Somehow they were able to punch out these gaskets by the literal millions 50 years ago. But with all the worlds advancements you can not get two of the same today.
rustyrodknocker is offline   Reply With Quote
Old 10-15-2011, 01:38 PM   #7
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I had this problem when I had a new windshield put in back in '08. The shop reused the old gasket & it leaked with the new glass. They tried to say it was bad seam sealer in the seams around the opening. I told them them it didn't leak before so it must have been something they had done. They installed it again with new rubber & no trouble since.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 10-15-2011, 02:24 PM   #8
bobs409
bobs409's Avatar
Thanks guys. I was just looking at it and see they used a black sealer just under the gasket surface but not sure on the glass to rubber area. I guess it could be getting in that way.
The gasket is Precision brand. I bought that ahead of time and let the glass shop install it.
Think I'll take the glove box out and run some water around to see if I can get it to leak. I'll seal up anything I find there.
Going to start keeping my insurance card in a zip lock too! It was doing the back stroke.
Bob
Old 10-15-2011, 04:42 PM   #9
CG
BlahBlahBlah
My K20 leaks like that. The glove box fills with water if I park with the nose uphill. So I park with the nose down hill. Now my bed fills with water because it is Rhino lined, but my glove box stays dry. One thing I do now though is to put all my paper work in a zip lock baggie just in case the water does find its way in there.
