Old 10-15-2011, 10:28 AM   #1
gmech
1 Ton Frame Reinforcments????
Hey, does anyone think that I should do any frame reinforcments on my 2wd 1 ton crew cab frame if I were to put a Duramax/Allison combo in it. Just plan to haul with it, nothing too extreme.
gmech is offline   Reply With Quote
Old 10-15-2011, 11:12 AM   #2
trout
Re: 1 Ton Frame Reinforcments????
id rather me safe then sorry but deffantly the front part here motor is
Edited by staff
trout is offline   Reply With Quote
Old 10-15-2011, 01:23 PM   #3
bikes&bowties
bikes&bowties's Avatar
In my plans of putting a cummins in my crewcab. 1 Ton 2wd frame converted to 4x4. I don't plan to box the frame. I don't quite see the need.. If you're worried maybe just box it back to the middle of the cab...
bikes&bowties is offline   Reply With Quote
Old 10-15-2011, 02:12 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What year truck?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-15-2011, 05:06 PM   #5
gmech
Its a 1991, I am doing a 2wd Crew Cab shortbed. Converting 4wd into a 2wd, Ive got it posted on the projects board. AKA old man.
Old 10-15-2011, 08:34 PM   #6
Goldfinger
Goldfinger's Avatar
Just put a few plates on the inside to box it . between the cab and bed on the inside add some flat plates because those are a weak spots. don't completely box them just as a few inches here and there and avoid putting them in places you need to get into for bolts. add another cross-member at the end for rigidity. that's all i can think of. Really the 1 ton frame is rather sturdy I've found it impossible to warp my 1/2 ton frame towing very heavy liquid trailers
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
