Old 10-15-2011, 05:51 PM   #1
mobileortho
mobileortho's Avatar
Not bad for a beginner
Making head way on the hood seam. Got all the holes filled, smoothed, bondo and primed. not bad for a rookie.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-15-2011, 06:28 PM   #2
watahyahknow
watahyahknow's Avatar
Re: Not bad for a beginner
looks good , bulbuous and concave objects are the hardest to straighten out i suggest you make it shiny using water and look at it in the daylight
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-16-2011, 08:49 AM   #3
mknittle
mknittle's Avatar
A flexible sanding board makes a huge difference
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-16-2011, 06:14 PM   #4
coralhead
coralhead's Avatar
Nice job but I agree on putting a dark shiny surface on there to see if you have any waves. Black primer and water will do the trick. I have the reverse problem from yours. I want to have the front emblem on my hood but the PO has removed it and filled in the dimples. If he left them I can grind out the filler but if welded in I suppose I will have to be emblemless.
coralhead is offline   Reply With Quote
Old 10-16-2011, 07:31 PM   #5
watahyahknow
maibe you can have the emblem airbrushed on
the only other way i would try is make a cardboard template using the hood from a stock truck to punch the holes in it transfer it to youre hood and drill the holes , that works even if he welded them shut
realy nice looking truck btw
Old 10-16-2011, 07:55 PM   #6
Atomsplitter
Atomsplitter's Avatar
Put your hood up for trade on Craiglist.
Lots of guys wouldn't mind you doing all the work for them and, hopefully, you can get a nice stock one in return!
Atomsplitter is offline   Reply With Quote
Old 10-17-2011, 06:36 AM   #7
coralhead
coralhead's Avatar
Thanks.....I have the truck in pieced right now and am going to look for the dimple locations. I like the template route and hope the dimples are still there.
