Old 10-15-2011, 07:56 PM   #1
vjjack04
vjjack04's Avatar
Radiator for for warmed small block
Any suggestions on a radiator:
Anyone used this one.
JEGS Performance Products 52050 - JEGS 55-57 Chevy Direct Fit Aluminum Radiators
vjjack04 is offline   Reply With Quote
Old 10-16-2011, 09:21 AM   #2
mbgmike
Re: Radiator for for warmed small block
we sell the direct fit two core aluminum for $299.00 from US raddiator. All made in USA
Notes Can Replace 23-1/2" Wide Core, For '55 1st Series use PN AL080081(6 Cyl) or AL080071(V8)
Material Aluminum
Available Cores High Efficiency Aluminum
Core Size 20 x 21-1/4
Available Rows 2
Cooler Size 12-1/2x1/4 NPT
Flow Type Downflow
Inlet Size 1-1/2"
Outlet Size 1-3/4"
part number AL080170ANDZ
or the higher flow model AL801702ANDZ for $399.00
shown in pic
mbgmike is offline   Reply With Quote
Old 10-16-2011, 09:56 AM   #3
Coupeguy2001
Coupeguy2001's Avatar
I have a 'Ron Davis Racing' radiator in the '57.
They didn't have any patterns at the time, so I brought my old radiator in for them to pattern. It took them 4 weeks to get it to me but probably now they have a few in stock and I had to get in line.
Now you can just order one, and they will build it quick.
Kind of pricey, but I haven't had any problems with cooling my pickup for 16 years with their radiator.
In 115 degree heat, (no A/C) my temperature with a real B&M engine oil cooler is usually around 180 with a 160 thermostat. I have changed coolant every 2-3 years, so I get most of the built up acids out.
If you install an aluminum radiator, be sure to ground it and use a sacrificial anode cap.
You don't have to remove any gussets with it, and the cap is in the middle along with the radiator hose just like the original.
Coupeguy2001 is offline   Reply With Quote
Old 10-16-2011, 03:38 PM   #4
OrrieG
OrrieG's Avatar
I'm running a 2.5 ton truck radiator in mine. 1" thicker and a little deeper, bolts to the stock small truck support location. I got mine from a truck that the guy got for the cab and front clip and was going to scrap the rest.
OrrieG is offline   Reply With Quote
Old 10-16-2011, 04:04 PM   #5
vjjack04
vjjack04's Avatar
Thanks. Where this says, gussets removed - what exactly does that mean? That is where the support attaches to the frame...
Old 10-17-2011, 09:44 AM   #6
solidaxel
solidaxel's Avatar
I have had excelent luck with a Stewart Components water pump and his High Flow
180* Thermostat
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-17-2011, 12:47 PM   #7
mr48chev
mr48chev's Avatar
i ran one of those for years and it keep the engine cool under a lot of conditions including towing a 15 ft travel trailer over mountain passes.
They are hard to find in good shape though.
Old 10-17-2011, 01:33 PM   #8
OrrieG
OrrieG's Avatar
I anticipate spending a lot of time running pretty slow in the hills. Also am setting it up to maybe tow a small Airstream type trailer. Mine passed an air test, still have to see if it will hold water under pressure.
Old 10-17-2011, 04:24 PM   #9
mbgmike
its just a partial notch
