tbi-carb
has anybody changed over from a tbi setup to a carb. setup. whats involved ? also can can i change from a 7.4 with tbi to a 5.7 with tbi ? is the computer the same ?
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
Re: tbi-carb
I know with my 454 tbi, it is adapted to a spreadbore intake. So in theory, you could change the distributor to a vacuum advance coil in cap, stick a spreadbore or squarebore with adapter plate on the intake. The most work would be in the fuel system. You would have to regulate the fuel pressure way down to get the electric pumps to work. It would almost be easier to put carb sending units in with an inline pump and regulator for a carb.
As to the computer, it is my understanding that the 5.7 has a different computer than the 7.4. If you have any questions about that pm RFMaster on this site, or go to www.tbichips.com. You can definitely get the info you need from either one of these guys. Good luck! |
Re: tbi-carb
thanks for the info wyattglock
Re: tbi-carb
No problem.
