Old 10-15-2011, 10:07 PM   #1
vettedad61
is the GVW the best way to tell a big block?
I have a 1972 Super Cheyenne big block, I was told it's a factory big block truck, it's a non-original engine (1973 454) the build sheet is long gone and the spid is missing, its been repainted a different color, the VIn in the cab is original and matches the frame, factory short bed, low hump, no heat sheild but has dual exhaust hanger.
I am trying to determine if this is a factory big block truck based on the gross vehicle weight on the VIN plate?
http://67-72chevytrucks.com/vboard/s...ight=vin+plate
vettedad61 is offline   Reply With Quote
Old 10-15-2011, 11:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: is the GVW the best way to tell a big block?
I don't know of GVW showing anything like that. The best signs of a factory big block would be exhaust hangers on both sides (no factory dual exhaust on small blocks), a heat shield on the lower passenger side firewall, and a high hump cab floor on all but 3 speed manual tranny trucks.
Old 10-16-2011, 01:29 AM   #3
71 super
71 super's Avatar
Check some posts by dantip, the gvw is the about the only way you can tell without the spid in a 1/2 ton 2wd. As I am sure you know the vin indicates only that it is a 8 or 6 after that without spid and the tell-tale parts- i.e. heat shield, dual hangers (three locations on both sides) correct parts such as remote reservoir, clamp to hold pressure hose at motor mount, correct mounts, auto cross member with guides for brake intermediate cable at trans mount, two piece drive shaft, 3.07 gear if auto. Thee are just off top of my head there are others. Might contact Paul Duncan as well he can help.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
