Old 10-15-2011, 11:32 PM   #1
iluvmy72
TBI to Vortec swap help.
Ok....background:
Have a 1994 3/4 ton that had a TBI 454 in it. Had a vortec 350 swapped in it. Along with that was the removal of the vortec intake setup. In its place came a very expensive Vortec intake made for TBI from GM. I plan on using the tbi setup from the big block. For the unit to mount i have an adapter that allows you to use the larger tbi. I will be going to the junk yard for brackets and other parts but that is it. Is there anything i need to change in terms of computer? Or will the older one work? I do have a computer for a 1991 tbi 350 but am not sure on that one either. What do I need? The layout of the new intake is quite different from the regular tbi setups.....can someone tell me what goes where?
iluvmy72 is offline   Reply With Quote
Old 10-16-2011, 10:20 PM   #2
davbell22602
davbell22602's Avatar
Re: TBI to Vortec swap help.
You need the vortec 350 wiring harness and computer too.
1990 Chevy C2500 4x2 350TBI
1997 Chevy K1500 4x4 350Vortec
davbell22602 is offline   Reply With Quote
Old 10-17-2011, 09:33 PM   #3
iluvmy72
Why do I need the vortec computer and harness if I am using tbi? Lol.... too many beers man:-)
Old 10-17-2011, 09:40 PM   #4
davbell22602
If your keeping TBI then just wiring harness. Vortec has 2 knock sensors and TBI has 1 knock sensor.
Old 10-20-2011, 09:56 PM   #5
iluvmy72
Why? What do I need the vortec harness for?
Old 10-20-2011, 10:09 PM   #6
69c10stepside
Large Member
69c10stepside's Avatar
I would compare stock hp on tbi 454 vs stock vortec 350 to see if the 454 computer would be enough for the vortec headed tbi 350.
Is the vortec 350 stock (96-98 factory stock)?
1989 GMC C1500 ECSB
1972 Gmc Jimmy
1972 Chevy C10 SWB Sold
69c10stepside is offline   Reply With Quote
Old 10-20-2011, 11:55 PM   #7
iluvmy72
Yes...she is a stock 96 motor minus the old intake....i am hoping it gets enough fuel.
Old 10-21-2011, 11:50 AM   #8
69c10stepside
Large Member
The larger injectors from the 454 TBI will be a good starting point... Anything past that is going to be trial and error
1989 GMC C1500 ECSB
1972 Gmc Jimmy
