Old 10-15-2011, 11:59 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Runability issue. Minor. Question.
I have a 1981 454 engine that was rebuilt with bigger cam/ different heads and i had the stock quadrajet rebuilt.
Issue im having is that it doesnt always idle. Some days it idles perfect all day. Other days, it idles fine at first then stops. I have to keep my foot on the gas.
Any thoughts???? Everything is hooked up fine. Why would some days it idle, then others it not??
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 10-16-2011, 08:06 AM   #2
chevypoint
chevypoint's Avatar
Re: Runability issue. Minor. Question.
Sounds like the choke is getting hung up. Check for vaccum leaks and to see if the linkage is rubbing on anything.
71 c20, 350/automatic
71 K5 Blazer, 350 3 speed (really my 16 yr old sons)http://67-72chevytrucks.com/vboard/s...d.php?t=686111
71 GMC build thread; http://67-72chevytrucks.com/vboard/s...d.php?t=468765
47 Chevy Aerosedan, 403 Olds/350 turbo
69 Camaro, 307/powerglide
06 Silverado Z71
chevypoint is offline   Reply With Quote
Old 10-16-2011, 09:59 AM   #3
geezer#99
geezer#99's Avatar
Primary throttle shaft is loose. Plates move sideways slightly and hang up on throttle bore. Changes your idle. I had one do the same. One of the little screws that holds the plate to the shaft was loose. Plate moved slightly.
Stroke the throttle by hand wide open and see if you can move the shaft side to side.
Old 10-16-2011, 02:09 PM   #4
lyrikz
PITbut
lyrikz's Avatar
Choke is moving freeely.
As for the throttle shaft, where is that located exactly? So open the throttle all the way, and then rock it back and forth to check for play?
I took the carb to a carb guy here in kirkland and right in front of me he tore the whole thing down, and put it all back together. Didnt mention anyhing about the shaft being lose. He put two small ball bearings into this two tiny holes and hammered them in. It idled fine for about ten mins then started to act up...
and sold.
Old 10-16-2011, 03:28 PM   #5
geezer#99
geezer#99's Avatar
Well that makes it easy. A no brainer. Take it back to the guy who rebuilt it.
I don't know where he might hammer 2 small bearings into.
Primary throttle shaft is in the bottom plate of the carb. When you stroke the throttle it has the 2 primary plates attached to it. The plates can be seen if you look down into the carb when you stroke the throttle. Below the choke plate. If the shaft moves side to side the plates can hang up in the bore changing the idle rpm.
Can you take a pic of your carb pointing to where he put the bearings in.
Here's a pic of a carb that shows the bottom side. The round plates attach to a shaft which runs from side to side. The round plates can hang up sometimes. In the pic the top 2 are the primary. Bottom 2 are the secondaries. This isn't a quadrajet but looks similiar.
http://67-72chevytrucks.com/vboard/s...d.php?t=489059
Old 10-16-2011, 06:48 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
mine was getting to much pressure. i had to put a regulator on it .
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-16-2011, 07:41 PM   #7
crazy longhorn
Fabricate till you "puke"
Take the return springs off the carb, turn it about 1/4 way open....then shake the shaft up/down(north /south)....you will find the slop in the throttle shaft That Geezer was talking about & I agree, that could be the issue. in that situation, the throttle plates do not set down in the same spot every time.This is a common problem on any 40yr old carb. Another Q , I might ask...to keep it running @ the light, does she load up(rop rop rop), before she stops? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-17-2011, 09:41 AM   #8
lyrikz
PITbut
lyrikz's Avatar
Ok, so take the air cleaner off, remove the return spring, then open the throttle 1/4 of the way and then shake the shaft up and down... So i reach INSIDE the carb to get to the shaft ya? I will give it a shot.
Yes, it does. it does the rop rop rop die... If i dont put gas to it.
Geez, the carb was in really good shape when i took it off the factory engine. basically cleaned it up. Then put it on the truck. Well, i was getting that idle issue so i took it to a carb place. He took it apart and plugged these two holes on either side of the carb. I wish i knew wht they were called. lol. Sorry.
and sold.
Old 10-17-2011, 09:57 AM   #9
geezer#99
geezer#99's Avatar
You can't reach inside. When you open the throttle just wiggle that part around to check for excess play. Up, down, sideto side. The throttle arm on the drivers side that the return spring is attached too is what you need to move around.
You don't need to know what the holes are called. We just wonder where they were located. Top or bottom. Inside, outside??
Old 10-17-2011, 10:01 AM   #10
lyrikz
PITbut
lyrikz's Avatar
Ok, i wiggled that and it feels REALLY solid. BUT, i had the return spring still hooked up.. i will try that again.
As for the holes. He took the whole carb apart and they were at the bottom. Says its very common and he does it to every quadrajet. It was INSIDE the carb near the front or the back. HOles were evenly spaced.
This guy owns carb connection in kirkland. He basically pulled the carb off, took it all apart, shook everything down, checked everything for play, popped two bb's in those two holes and put it back together. But, it still did the same thing. If i cant find any play or vacuum leaks (he couldnt find a vacuum leak either) then i will take it back i guess.
I am running a pcv if that matters at all??? I will get some pics of the carb and post em.
and sold.
Old 10-17-2011, 10:12 AM   #11
geezer#99
geezer#99's Avatar
Very little side to side movement can make it hang up. Where's your return spring hooked to? The spring could be pulling it sideways.
I checked your build thread. Spring to the back. Try hooking it up so it pulls straight forward. Spring in front.
Hooked to the back like yours might not be pulling it shut consistently.
Old 10-17-2011, 12:24 PM   #12
lyrikz
PITbut
lyrikz's Avatar
Geez, today when i get home, i will snap multiple picks around the carb so you can see.
Just to recheck, when checking for vacuum leak, get some carb spray, and with the vehicle running, you spray it around the base of the carb and if you get any idle pickup there is a leak somewhere.. The carb guy did that once before and nothing, but im willing to recheck. ahah...
and sold.
Old 10-17-2011, 10:08 PM   #13
lyrikz
PITbut
lyrikz's Avatar
Ok, here we go. I have video. lol. Take a peek, let me know what you think.. One pic has some text on it.
Click this pic for video.
and sold.
Old 10-18-2011, 10:54 AM   #14
geezer#99
geezer#99's Avatar
Geez Man!!! You take awesome pics!!!
The movement side to side would be enough to hang up the plates in the bore. Up, down is minimal. Shaft bushings appear good. The pic with the writing on it is your secondary lock out. THat movement might effect your changing idle but I suspect it's the side to side of the primary that's your problem. WE'll try the front first.
I'd move your return spring around so it's pulling from the front. Hook one end into that hole just below the cable hookup. You could make a temporary bracket that can be bolted down to one of your intake or valve cover bolts. A tall L-shaped bracket would work. Set it up to pull straight ahead. If that cures it you can get some nicer brackets on Summit.
Once we get that figured out we're gonna get you too replace that piece of rubber fuel line with a new complete steel tubing line. That rubber line is a big fire waiting to happen.
Old 10-18-2011, 10:58 AM   #15
lyrikz
PITbut
lyrikz's Avatar
Ok, so dont have the return spring behind it, you want it in front of it??? If that does not take care of it, whats the next fix?
That fuel line was supposed to be temporary... Putting it on my fix list now.
and sold.
Old 10-18-2011, 11:25 AM   #16
geezer#99
geezer#99's Avatar
Try it in front first.
Next fix could be pulling carb off, flipping it over, modifying the plate or limiting side to side movement. All the things you might not be familiar with.
The ones I fixed by just moving the spring helped.
If you need to talk it over pm your number.
Old 10-18-2011, 11:51 AM   #17
lyrikz
PITbut
lyrikz's Avatar
I will give it a try... To get it to happen i have to drive it say for 5 miles or 10 mins or so.. Shut it off for awhile, then drive again.. Then it wont idle. If i have time tonight i will try that... hope its as simple as that.
and sold.
Old 10-27-2011, 07:28 PM   #18
lyrikz
PITbut
lyrikz's Avatar
Ok, more info. This is just BAFFLING the hell out of me.
So that throttle you were talking about is good. Changed all that stuff you said and its good to go.
here is the situation. Start the truck up and it runs ok when its cold. As it warms up it runs fine but it just does not want to idle. BUTTTTT, pay attention to this part. If the truck is fully warm, and when i pull up to a light and i let it DIE by itself, then restart it, the issue doesnt come back. WTF!!!
Also, the damn thing when you start it cold, just doesnt start well at all. I think there is something messed up with the choke. I might get rid of the electric and go manual or something.
So what do you think. Why when its fully warm not want to idle. But the first time you let it die by itself. Then restart, it idles great for however long you want it to????
Thoughts?
and sold.
Old 10-27-2011, 08:56 PM   #19
lyrikz
PITbut
lyrikz's Avatar
Thoughts?
Well, i figured out one issue. So as i was staring at the carb, and the truck was idling. I covered with my hand the little top choke butterfly, and the rpms smoothed out and the engine rpm increase. I have a vacuum leak in this engine somewhere. So, i picked up a propane bottle and am going to go find the leak. Let you know once i have this figured. Think its weird the carb guy would miss somehting so obvious.
and sold.
Old 10-27-2011, 10:25 PM   #20
geezer#99
geezer#99's Avatar
So when you closed off the choke butterfly was the motor warmed up or still working on the choke.
Old 10-28-2011, 09:43 AM   #21
D.PASSMORE
One of the First
D.PASSMORE's Avatar
You could have a slight lean condition in the main jets - might not big enough. The main jets control the amount fuel that is pulled through the idle circuit. You can tell if it is lean by adjusting the idle mixture screws. If you don't get a noticeable response then its lean. Don't get the main jets confused with the metering rods - the metering rods control flow for cruise and response. I went through the same issue (all the above troubleshooting) and finally upped the size of the main jets in the Q-Jet carb and it runs fine. Took alot of reserch and reading but, I gained alot of base knowledge.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-28-2011, 10:02 AM   #22
lyrikz
PITbut
lyrikz's Avatar
Yes, it was fully warmed up when i coverd that area and idle smoothed out and raised up quite a bit.
and sold.
Old 10-28-2011, 11:09 AM   #23
geezer#99
geezer#99's Avatar
OK!!
Along the lines of D. Passmore's post. Maybe your metering rods are hanging up on the gasket. Runs lean cause they're stuck down in the jets.
Here's a link on quads. Lots of info.
http://www.digitalcorvettes.com/foru...ad.php?t=88376
Old 10-28-2011, 11:18 AM   #24
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Try this link too.
http://www.florida4x4.com/tech/quadrajet/index.php
Another indication was when you used your hand to cover the "area" and it smooth out is a maybe a tell sign that you need more fuel in the idle circuit.
Old 10-28-2011, 11:52 AM   #25
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by D.PASSMORE View Post
Try this link too.
Im going to check for leaks a bit better, then move on to this.
The other issue i have is that my damn choke isnt working correctly. Its not going on the high cam idle. Truck wont start for crap cold. I get out and manually open the throttle and flip the choke lever all the way up and then get in and she fires right off but as soon as i touch the gas pedal idle drops down.
and sold.
