Old 10-16-2011, 02:24 AM   #1
SILVER_WS6
72 Blazer topper/right door issue
Hey gang. I dont know whats going on here. My topper seal on my pass door has about a 1/4 gap. The seals are fairly new. I cant consieve what is doing this. The topper looks ok but can use some paint work. I know my body mounts are not the best but dont consider them shot. I have new polys I want to put on this winter. Anyone have this issue? Are truck and blazer windows different? I hope its not a 71 and older door. Will that do it? Im sure the seals are aftermarket but dont believe these are the issue?
SILVER_WS6 is offline   Reply With Quote
Old 10-16-2011, 11:51 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 72 Blazer topper/right door issue
It's probably your body mounts. You just got some sag from running with the top off. I need to replace my body mounts and I'm getting a similar gap.
Try running with the top like that for a bit, then loosen the top and see if you can get it adjusted. You may try parking on slightly uneven ground with to see if it twists the body just enough to close the gap - but be careful doing this.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-16-2011, 03:52 PM   #3
SILVER_WS6
Ah.> Good point. I did try adjusting the top but no good. Ill be trying the mounts when I get back. I have anew aluminum radior and core I need to put in. Then the mounts and the 700r4 conversion.. Its going to be a busy Feb for me!
