Old 10-16-2011, 12:14 PM   #1
barnold
barnold's Avatar
Blazer wheelbase
Ok I know the factory wheelbase on a 72 blazer is 114". But does this dimension change when running a porter built drop member front and a porter built 4 link in the rear. If I understand it correctly this dimension changes on the trucks when running this setup.
barnold is offline   Reply With Quote
Old 10-16-2011, 12:15 PM   #2
barnold
barnold's Avatar
Re: Blazer wheelbase
Correction wheelbase is 104" not 114"
Old 10-17-2011, 11:28 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Wheelbase at factory ride height is 104". When lowered on the factory setup, this shrinks due to the geometry of the suspension. The Dropmembers cure this, bringing the wheelbase back closer to factory specs at a lowered height, visually centering the wheels in the wheelwells. I would check directly with Nate for specifics, as it may stretch slightly more/less pending your setup.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
