10-16-2011, 01:45 PM | #1 |
How big of a difference...
Still running drum brakes on my 69 C10.Trying to plan and budget my next improvement,A/C or disc brake conversion.Right now the truck stops true and straight,and I live in a warm humid climate.Will the disc coversion make a very substancial change or just a small improvement?Are most disc conversions front only?Thanks.
10-16-2011, 02:06 PM | #2 |
Re: How big of a difference...
Most conversions are front only. The stopping is a big improvement. I'll let other chime in
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
10-16-2011, 02:26 PM | #3 |
Grandpa in the rustmobile...
Gee thats a tough one lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-16-2011, 02:38 PM | #4 |
67-72 parts collector,…
Brakes first!
10-16-2011, 02:40 PM | #5 |
both are a big upgrade
i'd go for the air conditioning first i've seen some donor parts trucks and have posted a few that i've seen on craigs recently that you can do a disc conversion for about next to nothing
10-16-2011, 02:52 PM | #6 |
Guaranteed: If you do aircon first, you're going to rear-end some moron with ABS who locked 'em up for a squirrel. Brakes, and it's going to be 140 degrees every day from May to October. Flip a coin!
10-16-2011, 02:55 PM | #7 |
The brakes seem safe{as far as drum brakes go}and I will stick with 6 lug even though parts may be less plentiful.The cab needs to be insulated for a/c, but what we call winter is just around the corner.Wish I could do both now.
10-16-2011, 03:23 PM | #8 |
If the truck stops true and straight with drums then I'll go with the a/c and disc brakes later. It may be cheaper to buy a good used a/c system out of a colder state, but buying donor truck with both should work maybe even buying a truck with someone else to get the parts you both need.
10-16-2011, 03:32 PM | #9 | |
10-16-2011, 06:16 PM | #10 |
I am a Referee of life.
Disc will stop some better but really shine in stop and go traffic,where fade is a problem.You could also add a power booster if they aren't power to make the pedal effort less.As long as they are in good shape and you drive it like a 40 year old truck,I see the drums as being fine.
A/c is an easy call.Everyone wants it some need it and some are lucky enough to have it already.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-16-2011, 06:32 PM | #11 |
Fabricate till you "puke"
I run a manual disc front/drum rear on my longhorn(no need for booster, the power brake lever is in my right hand) I like the feel of the system on my old longhorn, better than the feel of the 4 wheel power discs on my 02 silverado! I do like the air, & the cd player,ect in the 02. As mentioned above, the drum brakes do work fine (properly set up), but will fade under heat. Its your rig,do what you feel right with... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-16-2011, 06:49 PM | #12 |
Man...disks are so nice but damn! I've been to Florida...wouldn't do you much good if you are passed out from the heat!
My wife is a red head..she would require me to have air.. ;-D
Dave aka "Wild" Current truck "Ida Mae" 71 K5 Blazer Former Trucks "Loretta" 71 Longbed (AZ) "Tanya" 69 Stepside (AZ) "Ferdinand" 71 Longhorn (SD) "Patches" 67 Panel (IA/ KY) "Rosita" 68 C30 (KY) Instagram @Wildforwheels @k5_klub @c10university Profile pic provided by Jeff Sundance |
10-16-2011, 07:02 PM | #13 |
A wife is a wife, no matter what color hair Trust me on this one! crazyL
10-16-2011, 07:27 PM | #14 | |
10-16-2011, 07:39 PM | #15 |
A/C for sure... brakes are about half the price of a/c but unless your driving stop and go all the time, or downhill grades of 8% + for extended periods like 10 miles plus at time (learned that one the hard way...) 4 wheel drums work fine... a/c makes the ride all that more enjoyable epically when it is hot and humid.... and who wants to roll up somewhere dripping in sweat. Prime example: I was in wall drug, South Dakota on my way back from picking up my truck, I parked in the lot to stop and get some "free ice water" and an officer tells me nice ride, and then looks me up and down and says are you all right.... long story short I was soaked in sweat from driving in all day in the heat and was dehydrated, not cool... so i would go a/c
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-16-2011, 07:58 PM | #16 |
Been to Wall Drug as well, felt like a lab rat in a maze the way all the shops were connected on the inside.
No hills here, live at sea level. |
10-16-2011, 08:20 PM | #17 |
Glad im not the only one who has thought a/c. a/c in florida is a must in my mind. what i would try and convince her to do is let you put discs on it now and than in the spring ask for the money for a/c.
71 Chevy C10 350/TH350 71 GMC C20 350 (donor truck) 82 Chevy K20 Suburban 6.2/TH400/NP 95 Chevy 4x4 1500 Tahoe 6.5T/4L80E 04 Chevy 4x4 3500 Silverado 6.6T Duramax/Allison 1000 (work truck) 09 Chevy Aveo 1.6L/5 speed manual |
10-16-2011, 08:45 PM | #18 |
Junior Member
Proper set up drum brakes work just fine and even better if they have a booster.
I am putting manual disc brakes on my '67 from a '71 donor and probably will not go with a booster. I like the feel of manual disc brakes. If you do a lot of towing power disc brakes would be a good idea.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
10-16-2011, 09:16 PM | #19 |
Begging for forgiveness, is a bunch easier than asking for permissionI say do em both He11, whats the woman gonna do....spank you If you want to stay out of trouble....you probably shouldnt listen to this crazy old man! Have fun(let us know how the spankins go) crazyL
10-16-2011, 09:46 PM | #20 | |
After that you might get away with it.
