Old 10-16-2011, 04:40 PM   #1
daverod
SSN 706
daverod's Avatar
power brake booster on s10 layin frame.
I have a 52 on a s10 frame. I want to put my booster and brake stuff on the frame. I'm worried that I won't have room to run my exhaust and still lay frame. Any pictures or help from someone who has done this would be greatly appreciated.
daverod is offline   Reply With Quote
Old 10-16-2011, 07:42 PM   #2
Scottshotrods
Re: power brake booster on s10 layin frame.
Here is one more option for you we have our under the dash pedal assy that will work great in your truck.
Justin
Scottshotrods is offline   Reply With Quote
Old 10-16-2011, 08:15 PM   #3
daverod
SSN 706
daverod's Avatar
Justin
Where's that. I want it.
Old 10-16-2011, 08:20 PM   #4
Scottshotrods
Sorry about that go to our web www.scottshotrods.com. And when you are on the front page go to our links on the left hand side of the page you will see under scotts parts under the dash pedal assy and if you are interested in our product send me a e-mail at
Justin@scottshotrods.com and we give you a great deal on it and I have several in stock so shipping will be fast.
Justin
Old 10-16-2011, 08:27 PM   #5
daverod
SSN 706
daverod's Avatar
Thanks Justin. One more? if I have disk/disk do I need a booster?
Old 10-16-2011, 08:31 PM   #6
Scottshotrods
That is up to you if you want power brakes or not.I have a 67 c-10 with 4 wheel disc running 14 inch rotors and 6 piston cslipers running a wilwood manual master stops great.
Justin
Old 10-16-2011, 08:36 PM   #7
daverod
SSN 706
daverod's Avatar
Email sent. Thanks Bud.
Old 10-16-2011, 08:41 PM   #8
Scottshotrods
Resend your e-mail justin@scottshotrods.com never got it
Justin
Old 10-16-2011, 08:43 PM   #9
daverod
SSN 706
daverod's Avatar
I wish I had brakes like that. Mines just s10 stock in the front and the back is a zr2 s10. Just sent it.
Old 10-17-2011, 09:54 AM   #10
Layedoutsonoma91
Layedoutsonoma91's Avatar
any pictures?
Layedoutsonoma91 is offline   Reply With Quote
Old 10-17-2011, 01:34 PM   #11
daverod
SSN 706
daverod's Avatar
Originally Posted by Layedoutsonoma91 View Post
any pictures?
Just click on my build site for my 52 where it says "Click it"". Lots of pictures.
Old 10-17-2011, 02:49 PM   #12
cajundragger
I run a booster on my disk/disk. but Im lazy haha. as little effort as possible. If I get excited and mash the pedal I will go through the windsheild.
cajundragger is offline   Reply With Quote
Old 10-17-2011, 04:11 PM   #13
daverod
SSN 706
daverod's Avatar
I'm going to run a booster. When I was thinking about putting it on the frame I thought no booster might give me alittle more room to run my exhaust. Lazy makes 2 of us.
Old 10-18-2011, 08:10 AM   #14
MrDude_1
a hydroboost is smaller then most brake boosters... more reliable then the small aftermarket boosters too...
will the exhaust still fit by? eh, its tight. you can either make it work, or go around under the oil pan and have both exhausts on the other side of the truck (like a 3rdgen camaro)
MrDude_1 is offline   Reply With Quote
Old 10-18-2011, 11:28 AM   #15
1952ssr
1952ssr's Avatar
On mine, I used a X pipe and I think going that route you would have plenty of room to fit a small booster set up. Sorry that I don't have a good left side picture for you see. And I looked throught to build but didn't see a picture of how your set up is for placement of your cab and such. My running boards are quite lower than my frame so if I was layin frame they would hit first and the actual S10 frame never touch pavement allowing room to fit your exhaust.
Best of luck.
1952ssr is offline   Reply With Quote
Old 10-18-2011, 01:23 PM   #16
daverod
SSN 706
daverod's Avatar
My frame hits just before my running boards hit. I decided to go with the ounder dash set up. I'll let you know how it all works out. I'm sure there will be some things to work out. I like your exhaust set up.
Old 10-20-2011, 12:10 AM   #17
Scottshotrods
Dave
Your order was shipped out on wed thanks for the buss.
Justin
