Old 04-15-2003, 05:29 PM   #1
garyb
1999 tahoe front suspension noise
I have a 1999 2-door Tahoe with 66,000 miles that has a creaking noise coming from the front right side of the truck. It's most noticeable when you're going real slow and then turn left or right. It doesn't seem to matter if the brakes are on or not. Any ideas?
garyb is offline   Reply With Quote
Old 04-16-2003, 10:22 PM   #2
guitarman
Do it well or don't do it
guitarman's Avatar
Either upper or lower control arm bushings gone bad or a dry ball joint.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 04-17-2003, 01:31 AM   #3
Alexis
Member since 2000
Alexis's Avatar
i would not doudt if it was your hub.....once then get lose they allow crap to get inside and it go's to sht. Just take off the wheel. check it out...........99 is that the new style? I might be wrong. if it's a 4x4 you could also have a busted sleeve on the axel shaft.
Alexis is offline   Reply With Quote
