Old 10-16-2011, 10:51 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Building a new fuel tank?
My current place of employment has a shop full of TIG welders and extremely talented people to run them (I am not one of those people). I have been kicking around the idea of having one of the welders help me build an aluminum fuel tank. I could cut all the pieces and tack them together then have one of the talented guys run all the beads. The reason I am thinking about doing this is A) because I am going to be running an LS motor and might want a low sump on the tank for an external fuel pump. And B) just for the heck of it.
I'm picturing something simple and square, with the dropped down pickup and return tube...like this.
My question is what sort of baffeling should I put in? Does anybody have any pics of the inside of a nice aluminum fuel tank/cell for comparison? Also the cell pictured above is made from 0.100" thick aluminum, I would probably use 1/8" because that's what is around the shop. I'm guessing that would be strong enough material for underneath a blazer, right? I'm not going to be rock crawling or anything, just street and light trail use. Should I coat the inside with anything? Any ideas and thoughts are appreciated.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-16-2011, 11:02 PM   #2
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Re: Building a new fuel tank?
Subscribed... Cause I want the info as well lol cept in a Larger Scale and as an auxiliary tank on my flatbed
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 10-16-2011, 11:23 PM   #3
BLUE THUNDER
BLUE THUNDER's Avatar
Critter!!!!!!!!!!! Let's get together soon and work on the Blazers.
BLUE THUNDER is offline   Reply With Quote
Old 10-17-2011, 07:52 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
So is it done yet?
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-17-2011, 10:52 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Sounds good, I really need to lift the tub off the frame and I'm sure the more hands the better.
Originally Posted by Jtrux View Post
So is it done yet?
I hate you, is there anyway I can block you from posting on my threads???
I do have another problem, one of the guys at work reminded me of something I have heard before but didn't pay much attention to. Aluminum and Ethanol don't mix. I can't really get a strait answer as to whether or not the 90/10% mix at the pump will harm raw aluminum. Apparently E85 definitely will. Anybody have any first hand experience with this issue? Maybe I can coat the inside of the tank with something???
Old 10-18-2011, 01:32 AM   #6
oooooooooooooooooo thats a GOOD QUESTION!!!!!
Old 10-18-2011, 10:22 AM   #7
Critter
Future TOTM Winner
Critter's Avatar
Trying to do more research on the ethanol issue. Looks like its not so much the ethanol/alcohol that's the issue, its the amount of H2O that the ethanol attracts into the tank. When it mixes with the ethanol it reacts in a way that eats the aluminum when left alone for long periods of time. So it's an ethanol/water/aluminum mix that is bad! Once again, it looks like E10 wouldn't be a problem especially if the fuel is turned over quite a bit (aka the truck is driven and the fuel doesn't have a chance to sit and break down). I'm gonna talk to my boss about it, he is a genius when it comes to building things out of aluminum.
Old 10-18-2011, 10:26 AM   #8
coyote72
coyote72's Avatar
I will have to dig thru my pics. I built a tank for my Nova out of 1/8" alum. and baffled the inside. Another thing to consider is putting a bladder inside the tank, I had looked into that but its been a while. I will post those pics up soon.
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 10-18-2011, 01:30 PM   #9
Firebirdjones
Critter, I've been working up a plan to do the exact same thing.
I've already swapped the LS, and currently use an external pump with the stock tank and it works flawlessly.
However what I really want is an internal pump for noise and longevity purposes, but I also want a larger capacity tank, something in the 35 gallon range.
So I can solve 2 issues at once with a custom tank. I haven't seen anything off the shelf as of yet that will do what I'm wanting to do.
Firebirdjones is offline   Reply With Quote
Old 10-18-2011, 02:36 PM   #10
Critter
Future TOTM Winner
Critter's Avatar
Same here. We are thinking the same thing except I don't have a stock tank at the moment. So I would either have to get a stock tank and do what you are doing, or build one like I want. I would be happy with something in the 25 gallon range but either way I would like to put an internal pump in it.
Old 10-18-2011, 07:31 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
I'm thinking something like this, or maybe this will be enough to ensure I don't have problems. Both of them specifically say they work on all metals (I'm sure that would include aluminum) and protect against ethanol. I'm assuming most of the tank sealers out on the market will work so I'm going to proceed with the tank build and plan on sealing it with one of these.
Now I just need to decide what aftermarket in-tank pump to use.
Old 10-18-2011, 08:48 PM   #12
Firebirdjones
I was planning to use a sealer inside as well Critter. I've used stuff for old gas tanks that worked great to protect against scale and rust issues that I bought from Eastwood. Don't see why that wouldn't work for aluminum too.
Old 10-25-2011, 02:09 AM   #13
mcmlxix
Collector of Projects
mcmlxix's Avatar
A Walbro pump is the usual upgrade for intank pumps in the factory locations.
I was thining about the later EFI Suburban tank, but the 40 gallon is just too big and the 30 gallon requires moving crossmembers....
Check out my buld thread for a tank I was designing for my Chevelle... here
Here is a surge tank that you could install into a custom tank.... here
This website also has parts you can use to build your own surge tank.... like check valves
Rich
1972 K5 Blazer CST Click HERE
Old 11-01-2011, 12:16 PM   #14
Critter
Future TOTM Winner
Critter's Avatar
Ok, I need to do a little research I guess. What exactly does a surge tank do? Does it take the place of baffles and uses 1-way ports??? I'm checking out your links as well.
