Old 10-16-2011, 11:06 PM   #1
J.Cagle
J.Cagle's Avatar
Post pics of your 5 LUG wheels!!!!
I am in the process of converting my truck to five lug. The suburban donor I have has 5 lug rally wheels on it. I have the front in my truck and the rallys on it. They look ok, but ive never been a huge fan of ralleys on these trucks. I thought about trying to find some 5 lug steelies that will accept a hub cap, but I cant decide. What 5 lug wheels do you have? Pics please and where you found them!
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 10-17-2011, 01:42 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Post pics of your 5 LUG wheels!!!!
I’ve run a variety of 5 lug wheels on my 1960 GMC over the years. Here are a few photos showing the different styles:
Close up of 15x6 stock steel disc brake hubcap wheel:
15x6 stock steel disc brake hubcap wheels:
Close up of 15x6 Corvette style rally wheel with police car hubcap. Powder coating them black was kind of stupid because the slots disappear when mounted on the truck:
15x6 and 15x8 Corvette style rally wheels with police car hubcaps:
15x6 and 15x8 Weld Wheel Draglites:
Mid 50’s 15x6.5” Buick rims on the rear with early Dragmaster 5 spokes up front:
Same Corvette style rally wheels shown above, repainted silver with derby caps:
American Racing TTO’s, 15x5 up front with 15x7 on the rear:
15x7 TTO’s all around:
Old 10-17-2011, 01:48 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
Mark you`ve had some wheel changes over the years...the end result is worth it though..nothing like a set of tt`s
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-17-2011, 06:42 AM   #4
brokenspoke
brokenspoke's Avatar
A 1972 camper wheel is wider and takes a stock hub cap...the rear on my avitar shows the wheels
brokenspoke is offline   Reply With Quote
Old 10-17-2011, 07:24 AM   #5
J.Cagle
J.Cagle's Avatar
markeb01, where did you get the corvette rallys? Arent they 5 on 4.75? I love the looks of them with the police style hub cap!
Old 10-17-2011, 10:15 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
All of my 5 lug wheels are 5x5” bolt pattern. The rally wheels were sourced from Early Wheel in San Jose California around 1997. Most of the aftermarket wheel suppliers now carry this type and size wheel including Summit Racing, although you might have to shop around if you want a specific size:
http://www.earlywheel.com/products.h...ng-information
http://www.summitracing.com/parts/SUM-55-5773/
Depending on which disc brakes you have, there is a potential problem with running police car caps on these wheels (on the front of the truck). If you have the 1” light duty rotors, the spindle pin is shorter and the wheels and caps fit fine. If you’re running the 1.25” rotors (like I am), the spindle pins stick out too far and the hubcaps collide with the dust covers on the rotors, and won’t seat on the wheels. The solution is to flatten the end of the dust cover. I put each dust cover in a bench vise, with a large socket inserted into the cap. I then closed the vise until the end of the dust cap was flattened against the base end of the socket. Once flattened, the dust caps clear the hubcap just fine. Care must me taken to insure the dust cap does not touch the end of the spindle or the cotter pin, or it will chew away at the inside of the dust cap and ruin the outer bearing. It’s not very hard to make them fit correctly.
With derby caps there are inches of clearance no matter which brakes are installed.
Old 10-17-2011, 10:51 AM   #7
jchav62
1962 C-10
jchav62's Avatar
My '62 is converted to 5lug. 5on5. I'm running "Smoothies" on it now, used to run TTII's... The '65 is still 6lug... with Corvette style rally's...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-17-2011, 12:44 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My old wheels / current front wheels aluminum Mickey Thompsons
Rears are 15x12 Diamond Racing beadlocks
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-17-2011, 01:13 PM   #9
SIR
SIR
SIR's Avatar
...15 x 8.5 ,5 on 5
american racing "tto"...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 10-17-2011, 01:17 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
here is mine, 15X8 ralleys
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-17-2011, 03:10 PM   #11
J.Cagle
J.Cagle's Avatar
I put a cross member and rearend out of an 84 suburban under my truck. think the covette rallys with those police hub caps would fit? whered u get the hub caps?
Old 10-17-2011, 04:04 PM   #12
kieth
kieth's Avatar
My wheels are cragars, 17" X 9" front and rear....5X 43/4"-----I had changed everything over to 5X5 already had the wheels then realized they were the wrong lug pattern, drilled everything for 4 3/4 worked just fine.
only problem the rear tires are such a large diameter that we are having to move the rear axle back 1.5" will get that done soon. Kieth
http://kieth.smugmug.com/Trucks/66-G..._RGs9Wb7-X2-LB
kieth is offline   Reply With Quote
Old 10-17-2011, 06:06 PM   #13
Leadfoot Lambert
Leadfoot Lambert's Avatar
18x 8 Ridlers
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 10-17-2011, 06:12 PM   #14
J.Cagle
J.Cagle's Avatar
The ridlers are nice. I kinda thought about some 17" boss wheels that are gray in the middle
Old 10-17-2011, 06:43 PM   #15
steverino66
I like the old style 8x15" Cragars- found these on craigslist
steverino66 is offline   Reply With Quote
Old 10-17-2011, 10:34 PM   #16
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Post pics of your 5 LUG wheels!!!!
Mustang II IFS Suspension with 2.00" Billet Aluminum Wheel Spacers.
58 Ford Wagon 9” Rear End (Axle Length 57.25 inches)
Wheelbase has been extended to 117".
Front wheels: Weld Racing Draglite 90-Series Wheel 15 x 7
Rear wheels: Weld Racing Draglite 90-Series Wheel 15 x 12
Front tires: Falken Visa 912 Tires - 758 P215/65R15 96H
Rear tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT
(2) Subtotal: $369.98
Handling:13.99
Shipping:0.00
Tax:0.00
Total:383.97
http://www.jegs.com/p/Weld-Racing/We...FQ475QodMVA7Mg
(2) Subtotal: $467.98
Handling:13.99
Shipping:0.00
Tax:0.00
Total:481.97
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-18-2011, 10:10 PM   #17
SCOTI
SCOTI's Avatar
OE 71-87 plain front 15x6 steelies. Rear 16x10's built to 'look' similar. Aftermarket poverty caps....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2011, 11:47 PM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
I like it, that looks great!
Old 10-18-2011, 11:57 PM   #19
J.Cagle
J.Cagle's Avatar
Whered u get those hub caps SCOTI? They pretty pricey?
Old 10-19-2011, 12:08 AM   #20
likaroc13
Rollin' Old Skool
^^ love Scoti's setup....mine has stock 15x6 steelies in rear w/ 5x5 lug pattern...front will get the same once 5-lug disc conversion is complete
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-19-2011, 12:16 AM   #21
SCOTI
SCOTI's Avatar
I got them from an old board vendor. I recall they were around $40-50 each.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-19-2011, 01:13 PM   #22
65Gregg
65Gregg's Avatar
Mine are 15x7 front & 15x8 rear truck rallye's powdercoated black with a trim ring that is not as big as the standard "wide" style. I had to use what I had, as cast American TTO's will be the next step.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 10-19-2011, 04:26 PM   #23
J.Cagle
J.Cagle's Avatar
Got any pics of those installed on the truck 65gregg?
Old 10-19-2011, 05:36 PM   #24
flips72
flips72's Avatar
17x8 torque thrust 2, all the way around
flips72 is offline   Reply With Quote
Old 10-19-2011, 05:39 PM   #25
flips72
flips72's Avatar
oops, wrong picture, lets try this again
