Old 10-17-2011, 03:37 PM   #1
chevak20
Tilt column 79 and up
Why did GM change the steering column from 1979 and up?
From 1973-78 it had a clamp around the shaft and from 1979 and up it had a bolt through it and a not a spline surface.
Is the 79 and newer better construction? Did the prior clamp style spin around on some vehicles when the wheel was turned?
The reason I ask is that I am putting in an older style in my 82 truck and I want to be safe. I can change the bottom shafts otherwise and make a mix 77/82 style steering column.
chevak20 is offline   Reply With Quote
Old 10-19-2011, 08:06 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Tilt column 79 and up
im wondering now too
i wana put my 89 tilt colum in the 78
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-20-2011, 03:27 AM   #3
chevak20
I talked to a guy who works in the vehicle business and asked why they changed the design of this and he said that it might be a cost reason. Underneath the clamp style there must be splines, and splines are more expensive to manufacture than the double D design with a bolt through it.
I am going to go ahead and put this older style in my -82 4x4. The older style had been working well in my -77 2WD with no problems. I will post my obituary here if it doesn't work.
Old 10-20-2011, 09:21 AM   #4
Jonboy
Slots go on anything!
If you use the lower shaft also, it should go right in.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-20-2011, 10:25 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Cool I'm scrapping the truck soon and I am pulling the wipers and wires to figure out how to change that all over to the coloum with low and high beams too I hope
John
Old 10-21-2011, 08:03 AM   #6
madcow75
madcow75's Avatar
Makes sence they are allways trying to save money one way or another. I would think the splines would be stronger myself.
madcow75 is offline   Reply With Quote
Old 10-23-2011, 03:39 AM   #7
chevak20
I am starting to believe so too, I looked at a Jeep J20 pickup mid eighties yesterday and it had the clamp with splines style on it also.
