Old 10-17-2011, 04:20 PM   #1
biohazardbill
Order of Operations
In what order do you guys restore your rigs?
I went with suspension first after all a rolling chassis is easier to move around, but what next?
I want to get the body done so I can set it in place and mock everything up, wife wants to hear it run, all of it takes cash lol....
In what order do you guys do your thang? lol
biohazardbill is offline   Reply With Quote
Old 10-17-2011, 05:29 PM   #2
Surfdaddy
Surfdaddy's Avatar
Re: Order of Operations
The process I follow is like this: You first start on the rolling parts so you can move it around. Tires and wheel restoring, then the wheel bearings and brakes. Then I concentrate on the mechanical stuff like getting it running, shifting, stopping and suspension stuff. After that I’ll drive it a little (around the block) a few days to figure out what is in dire need. Once I get all the mechanical stuff worked out I’ll start on the bodywork, which I’m not too good at. It may seem like a lot of trouble but you know where you stand and what to budget for.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 10-17-2011, 05:40 PM   #3
jimmydean
jimmydean's Avatar
I start with "How much money do I have for stuff on this HUGE list..." and go from there. Sometimes the answer is easy, sometimes it's not.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-17-2011, 05:42 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The process as I was told, you take a part off and fix/restore that. Move onto the next part and so on. Tag and take pictures of each step as you go along. Label whether your going to fix or replace the part. On the list of parts, what finish will be applied, what's to be chromed etc. Group the parts as per the finish so they can all be done together. Once you've got it down to the bare frame, you reverse the process and put it back together.
Like i said that's what I was told. Some parts to the rule I follow, seems you need a lot of space and time to do it that way.
Old 10-17-2011, 05:45 PM   #5
krazy_texan
krazy_texan's Avatar
i start where the budget allows then once i get to that point i figure out what needs done most of all but to its all about how you do the restoration mine will never be off the road for more than a few weeks max just depends on what has to be done to it. I try to keep mine roadworthy or a driving restoration as they call it
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-17-2011, 06:06 PM   #6
k1rodeoboater
safety first (brakes/suspension, electrical, seatbelts, ect)
engine/trans/driveline
bodywork
Mine has sorta been all over the place, but I have more or less followed this
Necessity of certain things also dictate the order in which I have to do things.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 10-17-2011, 06:09 PM   #7
biohazardbill
Well the truck is down to bare frame, maybe i should have stated that.
If you were down to bare frame and ready to reassemble, what order would you go in, keep in mind the motor we have we have yet to hear run, so it may be junk although there isnt a bit of sludge in it as far as I can tell from removing the valve covers etc.
Old 10-17-2011, 06:51 PM   #8
k1rodeoboater
oh...well in that case....
1. do anything you're gonna do to the chassis (dropmember, ect) then paint (if you want the pieces as they came to you take them off, then paint, remount when dry)
2. suspension/brakes components
3. engine & exhaust, trans, driveshaft, rear-end (test engine at this point)
4. rust repair of cab while off frame (gonna need to brace it since it's off the frame) and any other bodywork needed
5. mount cab, and all the other sheet metal (especially replacement panels) to see how they fit
6. tear it all apart again and paint the sheet metal off the truck
7. put it all back together (CAREFULLY)
8. electrical re-wire
9. bed wood
10. windows down, arm out, rolling like a bad motha around town
that's what I'd do if I did a frame off
Old 10-17-2011, 07:14 PM   #9
biohazardbill
Done see above
Yeah I suppose this should be they way to go, just couldnt decide on body work or motor work, trans is a fresh rebuilt 700r4
cab is off, started on the rockers, cab is braced, wife complains cuz she still dont hear it run lol I wanted to get the floor of the cab done and mount it. just to keep fitting things together since nothing is stock.
9. bed wood
see above...
Old 10-17-2011, 07:33 PM   #10
k1rodeoboater
Well in the effort to appease household-6, when you get to step 3 try starting it. Reason is, if it doesn't start you can easily pull it and rebuild it at that point or get a new engine. Also the other reason to mount it on the chassis before you put any sheet metal on is that it's a hell of a lot easier to mount.
Old 10-17-2011, 07:39 PM   #11
biohazardbill
Looks like ill be driving to Summit racing this week lol
Old 10-17-2011, 08:12 PM   #12
Surfdaddy
Surfdaddy's Avatar
I did that on my Caprice. I looked at tit and started taking off the bent fender and after a very intense weekend, I had a lot on my mind and was just working on the car not paying attention on what I was doing. My wife looked at me on Sunday night and asked why I did that. I looked back and realized I had stripped the car down and had the body on one side of the garage and the frame on the other. I started the same process though. I stripped the frame, cleaned and painted, replace all the suspension bushings then did the wheel bearings, brakes and steering, and the wheels . Then I started on the drive train and then doing the body separately. It took me 3 years of constant work and the car turned out ok
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 10-18-2011, 02:46 AM   #13
pdxhall
pdxhall's Avatar
I agree. I always like to look at tit before I start a project.
pdxhall is offline   Reply With Quote
Old 10-18-2011, 08:24 AM   #14
Indian113
Indian113's Avatar
That's a tough one to Follow!!!!!!!!!!
Indian113 is offline   Reply With Quote
Old 10-18-2011, 09:01 AM   #15
kieth
kieth's Avatar
I found a rolling chasis that was bare for $100.00, this has become my mule, one can then remove the bed and put it on the mule chasis, then the front clip comes off, it goes on the ground for a while, then when the cab is off the cab goes on the mule and the front clip goes back on. now you have a bare chasis and you can still move the mule with all the body stuff on it around.
The chasis stuff is easy, it goes pretty quick, then the body work starts and it really takes time.......Kieth (body work is like chinese water torture)
http://kieth.smugmug.com/Trucks/66-G...38831944_KKWrH
kieth is offline   Reply With Quote
Old 10-18-2011, 11:27 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
step 1: find truck / pull from junkyard, barn, garage etc
step 2: Install unnecessarily big motor and trans combo
step 3: drive
step 7: get back around to everything else like brakes and seatbelts, and making sure its debatably legal to drive.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-18-2011, 12:06 PM   #17
Indian113
Indian113's Avatar
I have a dry erase board in my shop, I keep a list on it all the time. It has two sections
1 side is has to be done!
1 side is wants to be done!
I check off the ones I get done and dream about the ones I want to do
Old 10-18-2011, 02:56 PM   #18
rbar
rbar's Avatar
My dry erase board received a deadline date from my wife. It came and went, but buying a 415 horse G8 for her to drive got me an unlimited extension! Dry erase boards are expensive.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 10-18-2011, 03:00 PM   #19
Indian113
Indian113's Avatar
one side is more expensive than the other
Old 10-18-2011, 05:44 PM   #20
chad64chevy
chad64chevy's Avatar
biohazardbill, that frame looks sweet!! as far as starting the motor or doing the cab first! thats something that would be up to you, you can not put the frontend sheet metal on and the motor will still be easy to get to! i seen that you had your cab on a dolly and was starting working on it! so i would do the cab floor that way your not bouncing around! and you can see that your getting something done not just a bunch of lil things started an not finished!
chad64chevy is offline   Reply With Quote
Old 10-18-2011, 10:51 PM   #21
rustyrodknocker
This is the best idea Ive heard in ages.
rustyrodknocker is offline   Reply With Quote
Old 10-18-2011, 11:05 PM   #22
rustyrodknocker
I throw a used motor in it and start driving. when that motor does not go any more I get another. the drive it while you fix it up thing is a myth. enless your idea of driving is a sunday afternoon cruise. its really, drive while you wear it out somemore. like a new car I guess. Someday I would like to start over with a new to me rig and the motor would be absolutley last. you do not need a motor for a rig you are restoring. Intill its time to drive. I like everything to start so i dont have to push it. So the answer to that is find or make a place to work on it so it never has to move intill its done.
