headlights but no other lights??
hey i have a 79 c 10 and the other day i was under the dash and my shoulder bumped 2 random black wires together ( both had metal crimped connectors on them ) it was behind the glove box. anyways now i have head lights, blinkers and brake lights but no interior lights or running tail lights or license plate lights?? i just got a new switch didnt fix it and checked for blown fuses and none were blown any ideas?
Re: headlights but no other lights??
I'm not an expert on wiring, well actually I don't know much about it but I'm pretty sure black wires are grounds. I do know that without certain grounds your truck can pretty much go crazy with a mind of it's own so I would check your grounds first.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Back when I was in high school with my first car, I pulled the dash cluster out to change out the old burned out bulbs. When I put it all back together and turned on the lights, all I had was headlights............. Turns out after much anguish, it was just a blown fuse . I would check all of those, and check your grounds as mentioned.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
Check the wires you bumped. They might not have been crimped good and could have come loose when you hit them
![]() 87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift 2000 silverado extended cab stepside 5.3l. Stock for now |
