Old 10-17-2011, 05:58 PM   #1
bjhill1987
Tie Rod install problems
Hello, I'm attempting to install new tie rods on the front end of my 1971 GMC and cant get them to line up with the spindals. I have taken all the parts off the front cleaned painted and replaced what needed to be. When I attempt to put them on I can get one side on and the wheel on that side is straight, however; on the other side the tie rod is too long for the tire to be facing straight. Both tie rods are them same length 17" from center of bolts.
Anyone have any suggestions ?????
Thanks.
bjhill1987 is offline   Reply With Quote
Old 10-17-2011, 06:06 PM   #2
Lee H
Lee H's Avatar
Re: Tie Rod install problems
Do you ave the tie rod installed in the adjuster far enough?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-17-2011, 06:17 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Got any pics?
Keith
Convert to disc brakes.
Old 10-17-2011, 06:18 PM   #4
bjhill1987
Yes I have them all the way in.
Old 10-17-2011, 08:23 PM   #5
57larry
or you could take the truck to get the front end align and let the alignment guy figure it out
57larry is offline   Reply With Quote
Old 10-18-2011, 11:15 AM   #6
bjhill1987
Yea, I'm not ready to bring it to the alignment shop yet too much work needs to be done. But here is a pic sorry its sideways but you can see that the driver side is on and the rotor is facing forward but the passenger side is kicked out.
Old 10-18-2011, 12:59 PM   #7
Lee H
Lee H's Avatar
The outer tie rods look way to long. Mine are 7 3/8 inches from end to end, and the inners are 9 5/8 end to end.
Old 10-18-2011, 04:56 PM   #8
lolife99
lolife99's Avatar
Got any closer pics of the tie rods?
The inner tie rod nuts should be on the front side of the centerlink.
This is a common mistake to install incorrectly.
Keith
Old 10-18-2011, 05:02 PM   #9
hayhauler71
hayhauler71's Avatar
Is the steering gear box centered. The idler arm and pitman arm should be straight with the frame or close.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-18-2011, 05:12 PM   #10
bjhill1987
lolife99, I can take more soon. This is kinda an old pic I think the centerlink was installed wrong in this picture but I have since corrected that and the bolts are now facing forward. I have also measured the tie rods and they are the same measurements given above. I also centered the gear box before attempting to install the rods.
Thanks for yalls help.
Old 10-18-2011, 05:42 PM   #11
Wrenchbender Ret
If the steering box is on center adjust the tie rod sleeves till the wheels point straight ahead. You can get it close by eyeball & check it when you get it all together or take it to the alignment shop.
Wrenchbender Ret is offline   Reply With Quote
Old 10-18-2011, 06:36 PM   #12
Robznob11
Robznob11's Avatar
Is your drag link a 71-72 . I dont remember the issue but my center is 68 and spindles are 71-72 this requires a custom tie rod adjuster and a mix ou tierod ends like useing inners for outers cpp knows the correct ends and sells the adjusters
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
