Old 10-17-2011, 07:16 PM   #1
Spot1984
Lowering 6" in rear....shim?
I'm lowering the rear 6 inches in my 70 swb. I was wondering what degree of shim I would need. Thanks guys
1970 Chevy C10 shortbox- 454
1970 Chevy Nova- 383
1987 Grand National
Spot1984 is offline   Reply With Quote
Old 10-17-2011, 08:49 PM   #2
CC69Rat
CC69Rat's Avatar
Re: Lowering 6" in rear....shim?
I would say ~4 deg. Coil springs or leaf rear?
I have two C10s and one S10 I have used these blocks and shims, and I wouldn't buy them from anyone else. http://www.jagsthatrun.com/Pages/Par...lignShims.html
Not my site just a highly recommended vendor. they sell shims, blocks, Ubolts, etc. Anything you need. Hope this helps.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-18-2011, 12:22 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Curious why you're needing a shim. Lowered mine with a 6" drop spring with new u-bolts and didn't have any issues. Also, don't forget the shock relocator's...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-18-2011, 12:50 AM   #4
gearys 5600
gearys 5600's Avatar
x-2 ...
Mine is lowered 7" in the rear with no shims and no issues.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-18-2011, 06:05 AM   #5
CC69Rat
CC69Rat's Avatar
With C10s and / or the trailing arm suspension setup it may not be something 'required' to run however on my S10 ext cab (2.85" rear drop) I had to run a 3 deg shim to pull the pinion back around to factory spec. (It's actrually better than factory). It's just a safety thing to make sure when the geometry changes my bet would be the pinion angle would change a bit too. It may not be something noticable on the C10s (?) This is my first time building one.. Personally I plan to spec mine to 1 deg neg at the pinion. If it takes a shim, so be it. If not.. Even better. Out of curiosity, Nate (or X2). With a 6 or 7" drop and no shim, where does it put the pinion in relation to the drive shaft / U joint? I don't know, just wondering.. It may not be something even needed on the C10's. In no way doubting you guys.. Just trying to learn the C10s.
With my experience (Lifted Jeeps, dropped S10) Pinion angle has been something to consider and it may not be necessary on the trailing arms (?). Cool stuff man.
Later
Chad
Old 10-18-2011, 08:30 AM   #6
Sammy
I could be wrong but was at the understanding that 6 is the exact max limit recommended before needing pinon angle adjustment due to possible early failure rates. Can anyone clear this issue up? Two piece shaft might also play a huge factor also. Shock relocating mounts would be almost a must do.
If so that would explain why some see as a non-issue others do..???
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-18-2011, 10:04 AM   #7
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I have a short bed with a 6" drop and a 1 pieace drive shaft and Ford 9". With out the 4deg shim I got a vibration. Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-18-2011, 10:08 AM   #8
OJ1988
Just a car guy
OJ1988's Avatar
Get an angle finer, and measure you pinion angle, and tailshaft angle. Thats the only way to know if and how much shim you need.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-18-2011, 10:44 AM   #9
firedog
firedog's Avatar
No shim on my bagged truck but there is a certain height that if I am driving at 45 there is obvious out of balance noise but just a flick of a switch and it's gone...
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 10-18-2011, 10:45 AM   #10
leddzepp
Moderator
leddzepp's Avatar
bingo.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 10-18-2011, 10:56 AM   #11
OJ1988
Just a car guy
OJ1988's Avatar
Should be finder not finer.
1973 Vega Drag Car
1970 C20 tow rig
