Old 10-17-2011, 08:27 PM   #1
Daytona#3895
Daytona#3895's Avatar
Lift question
I have a 1987 k-10. This is my first lifted vehicle. I always had muscle cars. The truck has a 6" Superlift kit with 35x12.5x15 BFG All Terrains. It seems to be a good kit. I am not sure what kit it is though. It was on the truck when I bought it. There are no lift blocks, it is all spring. Rear springs have 7 leaf. 6 normal size leaf and 1 that looks like its 2 to 3 times thicker. It may be a helper. Its closest to the axle and its the shortest. The front has 6 leaf. I have the factory quad shock in front and the normal 1 shock per side in the rear. I also have dual stabilizers up front and a drop pitman arm. The sway bar is intact and lowered accordingly. I checked the entire front end as well as the rear. All is working properly and nothing is loose, worn or damaged. My question is, being its my first lifted truck, do they all ride like tanks? It is the worst riding vehicle I have ever been in! The suspension doesn't give or flex at all. Every little bump I hit, my head wants to bounce off the roof! Is this normal? I doubt if softer shocks would lessen the bouncing. The springs don't budge. For a daily driver, its a bit much and is taking all the fun out of driving it. Do I have to swap out for a more softer spring or is it just how it is?
Current vehicles
1987 Chevy V-10
2006 Dodge Charger R/T Daytona
2004 Jeep Wrangler Sport
1996 Jeep Cherokee Classic
1968 Chevy Camaro SS
Daytona#3895 is offline   Reply With Quote
Old 10-17-2011, 08:38 PM   #2
b454rat
Re: Lift question
Take one of the shocks off up front, probly make it little better. It's hard to get these trucks to ride "decent". The lift kits aren't the greatest either. Want good springs, have to pay good money.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 10-17-2011, 08:50 PM   #3
PaRedneckRiders
Re: Lift question
My truck has a cheaper lift on it, its 4in blocks in the rear and 3in body lift but mine rides like a tank also. I just have the single shock up front.
I guess its just something i have learned to live with since it doesnt seem to bother me much anymore although i do plan on redoing all the suspension with something different eventually.
PaRedneckRiders is offline   Reply With Quote
Old 10-17-2011, 09:09 PM   #4
Your41Plague12
Your41Plague12's Avatar
Re: Lift question
I have a suspension and body lift on mine and it's just as you described. I've hit my head off the roof before. I have 6" springs in the front, and factory 3/4 ton leaves in the back with a 4" block and an add a leaf in the back. It has ZERO suspension flex.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-17-2011, 09:19 PM   #5
Daytona#3895
Re: Lift question
Thanks for the input. I guess its just how a lifted truck rides. I will just have to get used to it. Haven't been off road with it yet. When I do, I will be sure to where a helmut......
Current vehicles
1987 Chevy V-10
Old 10-17-2011, 09:24 PM   #6
Your41Plague12
Re: Lift question
The lift kits for these trucks leave a lot to be desired if you buy it from a kit. Depending on how much lift you're looking for, you could go with a shackle flip in the rear and move the front spring hangers to fit 52" stock rear half ton springs in the front. This will net about 4" of lift and flex nicely. There is more to be done though, if I remember right a zero rate needs to be added under the springs in the front to relocate the axle to the correct position. Lots of guys have done this, and with a good set of 33's or a narrow set of 35's you'll go anywhere (within reason, of course) and it won't ride too roughly.
Steve
Old 10-17-2011, 09:29 PM   #7
Daytona#3895
Re: Lift question
That could be something I could look into. I have had the truck for about 2 months now. Have a lot of minor repairs to make before I tackle that. It has the typical slow window motors/regulators, a slight bog under WOT acceleration, and a heating issue. The mode door moves from defrost to vent to floor when i set it cold. When I set it to hot, it just comes out vents. Tackle that this weekend before the New England winter sets in.
Current vehicles
1987 Chevy V-10
Old 10-18-2011, 05:59 AM   #8
dman1982
dman1982's Avatar
Re: Lift question
check the shocks, make sure the bushings are good togo, and see if everything is tight as far as she shocks and shock absorbers, my truck also rides like a tank but i did these few things and it made a world of difference, but still rode like a tank
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
