10-17-2011, 09:44 PM | #1 |
Remote starter in '86
I have a 1986 K5 that I am looking to put a remote starter, wondering if anyone has gone down this road and if you have any advice. With it having a carb I need to line up my A/C solenoid to push the throttle and have it give a little gas when it cranks, or else it will just sit there and try to start over and over again.
G |
10-18-2011, 07:36 AM | #2 |
Re: Remote starter in '86
I am not sure what you mean by associating more gas needed with remote starter, but the remote starter issue has a contentious history on this forum. Some are opposed to them, believing that you are just covering up a problem with your stock starter/solenoid/wiring arrangement. Others, like me, think they improve starting by addressing "heat soak" in the stock starter/solenoid setup. You should search "remote starter" on this forum for a complete (and heated) discussion.
If recommend a manual choke for any choke related hard start conditions - less than $15 experiment - well worth the effort. Likely any cold start issues will be overcome with a manual choke. |
10-18-2011, 09:11 AM | #3 |
The reason I want a remote start is due to this truck being my winter beater, and i would love to hop in a warm winter beater, not a cold one. The truck has the electric choke on it right now. What I have been told is that due to it having a carb the remote start isn't going to work very well seeing as when you start the vehicle manually you typically give it a pump of gas.
10-18-2011, 09:13 AM | #4 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-18-2011, 10:26 AM | #5 |
My bad - I thought you meant remote starter/solenoid setup.
10-19-2011, 12:27 AM | #6 |
No worries tuscon.
cochino-- what part number did you use and how exactly did you have it wired/set up, if you don't mind sharing. I am thinking of trying to get the a/c solenoid lined up to give the throttle a push, but problem is that it is always engaged when the ignition is on, so it won't return to the off position once the vehicle has started. G |
10-19-2011, 10:40 AM | #7 |
78K & 79C Jimmys
the AC solenoid won't push enough,it just raises the idle
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-19-2011, 06:57 PM | #8 |
electric choke it should run fine i would think
10-19-2011, 07:05 PM | #9 |
78K & 79C Jimmys
The pedal still needs a good push to set the choke up.
10-19-2011, 11:15 PM | #10 |
motornut-- The A/C solenoid in the stock position is not enough to move it, so I am thinking of fabbing a bracket so that it sits underneath the throttle and pushes a part of the linkage up and that should pop it enough.
G |
10-20-2011, 12:00 PM | #11 |
78K & 79C Jimmys
not sure if that even in a different spot ,that only moves a little bit
you need a good pedal to floor to set it up i looked into years ago 92 i think and looked at a custom setup done by Derand and it was a door lock type part mounted in carb area I didn't bother,the viper i got sometimes it would fire up while warm wouldn't bother in the winter,but use the autostart after you start it start like norm,in park push the starter button,take the key out or park with it running,push,remove key,run into store,come out and put key in drive away most do this still today
10-20-2011, 10:19 PM | #12 |
Alright, thanks for the tips. I will have to look around the web and see if I come up with anything. I wouldn't bother with the remote start if I didn't have to go to school in January, the one I bought has a timer on it so I was planning on setting it up so that it turns on for ten mins before the bus arrives. If I wasn't going to school then I would just start and then go sit in the shop for a bit while it got warm.
G |
