10-17-2011, 11:56 PM | #1 |
Junior Member
Big Back Window Conversion
I want to do a Big back window conversion. I found a 62 big window and I have a 64. Is that section of the cab the same? Any help on this would be appreciated.
10-18-2011, 08:15 AM | #2 |
Re: Big Back Window Conversion
Don, I really don't know, but I would say yes. The A pillers are different for sure, but the rear of the cab is the same. However, as I always answer to questions like yours. "With enough money, a welder, and a big hammer, one can make anything work." Good luck and let us know how it works out.
Shorty |
10-18-2011, 09:16 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
same
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-18-2011, 09:22 PM | #4 |
Junior Member
Thanks for the info. I also thought they were the same but it never hurts to ask. I went and bought the back section of the truck today. Thanks again
10-18-2011, 09:27 PM | #5 |
1961 crewcab
there should be a thread in the faq section, all you need to use is the inner panel, and they are the same.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-18-2011, 09:57 PM | #6 |
Junior Member
thanks jonzcustomshop I will check it out
