Cab dimensions
Can someone who owns a 99-06 Extended cab pickup measure the dimensions of the cab. A buddy of mine wants to drop one onto a blazer frame and wants to know the dimensions. Thanks guys.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
Fabricate till you "puke"
Re: Cab dimensions
I think that cab will be a little long for a blazer frame, but I have an 02 1500 extended. What do you need(center of the front wheel,to rear of the cab?) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: Cab dimensions
101 1/2", center of the front spindle to the rear of the cab.... crazyL
