![]() Join Date: Sep 2008
wtb 3/4 ton 8 lug drop spindles
i need a set of drop spindles for my 72 c20 8 lug. the 1/2 tons are everywhere but i need 3/4 let me know what you have
Re: wtb 3/4 ton 8 lug drop spindles
If you don't find any from a board member, these were the only ones I found online (courtesy of lolife99, thanks brotha) their a little pricey, but so goes supply and demand
![]() http://www.performanceonline.com/197...P-SPINDLE-SET/ Good luck brotha, Ryan
Blessings, Ryan G JESUS IS LORD!!!!!! ![]() |
yea i seen these but are pricey. seen some used sets on here before. came off the next body 73 and up trucks.
So, will the 73 drop spindles work on a 71-72 with disc brake??
does anyone have a set
ttt
ttt who has a set of these??????????????????????????
67-72 parts collector,…
![]() Join Date: Nov 2002
You can use the 73-87 spindles on a 71-72 truck,... but you will have to change the upper balljoint and outer tie rod to the 73-87 version.
I know these seem kinda high priced,... but they are definitely in less demand than the 1/2-ton versions.
Also they are about the same price as the new CPP modular spindles with the 12" rotor bracket. I would buy new, so you know what you are getting.
but from who is the question. i heard airbaggit.com is crap. and gmc pauls say they have the 71-87 3/4 ton spindles but they are not listed in there catalog.
