Light switch bezel nut
Are there original style light switch bezel nuts available for my '64. I have found some aftermarket ones that are not very close. I replaced the switch but can get the old one out becasue the bezel nut wont turn and it is getting to the point of just having to drill it out and replace. A good used one would work for me too.
Thanks!
1947 Art Deco Chevy truck 1964 C20 Custom cab 1965 Tempest Wagon 1967 GTO 1972 Luxury Lemans http://www.cardomain.com/id/a67goatnut |
1961 crewcab
Re: Light switch bezel nut
try what you can to save yours, can you soak it down with some penetrant?
they do not repro them, why I do not know... so you need yours, or a used one.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I may have a used one, ill look on my parts truck when i get home
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Clyde65,
If you would be so kind to take a look for me I would appreciate it! Let me know what you find. Thanks again!
here is the bezel. pretty clean, a few spots that are a little boogered up but nice. If you want me to send it to you, send me a PM with your address and such.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 10-18-2011 at 06:10 PM. |
Can somebody fill me in on how to remove these damn things? Anything you can offer is appreciated.
Can anyone fill me in on how to remove these things?
if your talking about getting the pullrod out of the headlight switch unit so you can get the nut off, The way to do it is reach under the dash and feel around the headlight switch unit for a small button you press in, when your holding the button in turn the headlight switch knob/rod and turn it (i belive all the way to the left been awhile) and pull out and it should come all the way out(might have to turn back and forth and push and pull till it pops out i have had some stubborn ones before)..Then you take a flat blade put it in the slot like in the above picture of the nut, and un screw....hope this helps
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
Huge help....thank you.
Posted via Mobile Device |
when ya put it back in - dont force it - sometimes - not always -if forced they bend
been der - it sucked ! |
![]() Join Date: Oct 2010
You can always take a used nut and wetsand and polish it if you need for it to look new.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
My experience was that...
I had to pull the knob out as far as it would go then depress the release button on the switch then remove the know the rest of the way. It did me no good to depress the button first prior to pulling the switch from the Lights out" position.
