Old 10-18-2011, 02:18 PM   #1
65 on 24s
65 on 24s's Avatar
got a break q?
Ok hears the deal. My 65 c10 has had a 73ish breaks,a-arm and crossmember swap. My q is im wantin to replace the m/c and booster. Do i need to buy a bootser for my year and a m/c for the 73ish or booster and m/c for 73ish.
65 on 24s is offline   Reply With Quote
Old 10-18-2011, 06:47 PM   #2
scum1
scum1's Avatar
Re: got a break q?
i got a booster from a 73-87 and a m/c also..that way you can split the brake lines unlike the stock m/c. and a proportioning valve also..all from a junk yard!
scum1 is offline   Reply With Quote
Old 10-18-2011, 07:17 PM   #3
65 on 24s
65 on 24s's Avatar
Re: got a break q?
Did the stock booster bolt right up or did u have to drill more holes. My next q is my truck has rear disk breaks would i be best to put a stock proportioning vavle and add ajustable one.and idea on that
Old 10-18-2011, 07:51 PM   #4
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: got a break q?
Got the same brakes on mine, i bought a '72 corvette MANUAL disc brake booster. Added the proportioning valve out of the same '73 c10 ran two new front brake lines and the original line became my rear brake lines. The master bolted right up, needed no adjustment to the pushrod. Has worked fine and no problems that I've noticed, been this way for about a year and a half and gets driven regularly.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 10-19-2011, 08:53 AM   #5
65 on 24s
65 on 24s's Avatar
Re: got a break q?
Anyone got pics
Old 10-27-2011, 10:56 AM   #6
65 on 24s
65 on 24s's Avatar
Re: got a break q?
Ok a buddy of a buddy of mine has a 85 c10 that he is partin out will the m/c and booster bolt up or do i need to pass this up. I can get it off the truck for $25
Old 10-28-2011, 12:04 AM   #7
Captainfab
60-66 Nut
Re: got a break q?
You'll just have to drill a few holes to bolt it up.
Old 10-28-2011, 12:42 AM   #8
pdxhall
pdxhall's Avatar
Re: got a break q?
How did you break your q?
pdxhall is offline   Reply With Quote
