Old 10-18-2011, 04:49 PM   #1
SkeksisNV
SkeksisNV's Avatar
Heater Control Assembly Levers...
Mine are hard to move. Is this something that I can fix with lubricants around the house? Or am I going to be looking at replacing parts? The main one that is hard to move is the top one. I am not certain what it is control since the labels are gone. I planned on buying a rebuild kit for it along with new cables, but wanted to see if I can get it half way working for the time being. I appreciate the suggestions, thanks
Gary
'71 3/4 ton pickup, 350cid - TH350
I know just enough to get me in trouble
SkeksisNV is offline   Reply With Quote
Old 10-18-2011, 05:07 PM   #2
webfoot
Re: Heater Control Assembly Levers...
Top is heat/defrost control. Follow the cable and move the lever and see if the door moves freely.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-18-2011, 05:12 PM   #3
RUSHNBOBO
Take off the cables and spray a liberal amount WD40 or your favorite penetrating oil down the cable and work them until they free up...also lube the lever pivots on the back of the control panel as well as the defrost door, the heat control and core control lever pivots.
Some of the new rebuild kits have steel levers instead of pot metal, make sure you get those; ten times stronger.
RUSHNBOBO is offline   Reply With Quote
Old 10-18-2011, 06:14 PM   #4
SkeksisNV
SkeksisNV's Avatar
Well after going out and inspecting, two of the cables weren't hooked up. The Fan and the heat one. I got them hooked up and cables realigned so that they will stay on. The defrost cable is on and it is still hard to open and close. I will take the advice here and lube up the cable and pivot point. I will determine at that point if its the door itself that is hard to open or the cable maybe being gummed up too. Thanks for the help guys
Gary
Old 10-19-2011, 06:25 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Also make sure the cable doesn't have a kink in it.
Hard to move levers are common on these as well as broken ones!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-19-2011, 11:11 AM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Yeah kinks wont move well at all either.
John
1999 Toyota Tacoma 4x4
Old 10-19-2011, 12:15 PM   #7
cdowns
cdowns's Avatar
40 year old moving parts respond well to cleaning and lubrication
Old 02-26-2014, 02:03 PM   #8
ol_skool_chevy
ol_skool_chevy's Avatar
Anyone have a photo of the back side of a 1966 heat control cable assembly? I am rebuilding mine..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
