Truck Nut
![]() Join Date: Jun 2007
14 bolt FF gear ratio ? ? ?
Was it possible from GM to get a 3:21 gear ratio in a 14 FF ??? I have like 6 of them and just wanted to know if that gear ratio was possible before I go counting gears. I know you could get that in a semi floater and of course I have none of those.
Im looking to keep my 400 turbo but, have highway gears. Im converting my SRW to DRW but have decided to use Arrowcraft adapters for the rear.
Tony Kee Texas Square Bodies |
Re: 14 bolt FF gear ratio ? ? ?
It looks like the answer is no from GM, but it is available in an aftermarket gear set. I do see a GM part# 14-342 for 3.42 gears.
http://www.pirate4x4.com/tech/billavista/14b_bible/
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
Truck Nut
I had a 3/4 srw truck with a 3:21 that came stock in it. I parted it out years ago. I probably have one. Just gotta look
From my research they did come from gm mostly in the pre 1980 models though. suposedly a "rare" option.
If you find one I would be looking for a set if the price was o.k. I am swaping to an overdrive but am aslo swaping a cummins into mine 1987 reg cab dually R30 |
