Old 10-18-2011, 11:06 PM   #1
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Complete Power Brake Booster Assy
I have a good used power brake booster with master cylinder and prop valve for sale 80.00 plus shipping
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 10-19-2011, 12:41 AM   #2
guitardude127
Re: Complete Power Brake Booster Assy
What is this off of? I'm wondering if it will work on my '69 GMC 2500.
guitardude127 is offline   Reply With Quote
Old 10-19-2011, 05:37 PM   #3
chevytruckluver
This one came off of a 71 1/2 ton
The 3/4 ton units are a little larger, so it wont work for you, sorry
Trey
72 Short Step
Old 10-19-2011, 05:45 PM   #4
72peace
72peace's Avatar
Is this prop setup drum/drum or drum/disc?
Thanks,
72peace is offline   Reply With Quote
Old 10-19-2011, 05:47 PM   #5
chevytruckluver
Thanks,
It is a disc/drum
Trey
72 Short Step
Old 10-20-2011, 09:10 PM   #6
72peace
72peace's Avatar
Sorry, having to pass on a few things. Forgot car tags this month.
Cheers,
Old 10-23-2011, 09:44 AM   #7
chevytruckluver
w/e bump
Trey
72 Short Step
Old 10-23-2011, 09:37 PM   #8
Zombiefied
Pardon my ignorance but.... Is this everything I need to switch my 70 1/2 ton over to power brakes? I was told I needed the front lines. I have manual with discs already swaped up front and drum rears. How much for shipping to 72401? Thanx
Zombiefied is offline   Reply With Quote
Old 10-24-2011, 08:33 AM   #9
chevytruckluver
ignorance? I am not an expert on all the diffrent conversions that can be done to these trucks. I do know if I were going to convert I would do it this way.
Since the brake lines on your truck go directly to the master cylinder they would need to be bent to be moved to connect to the prop valve on the power assy.
I am not sure if there would need to be any other mods
hope that helps
shipping to you...20.00
Trey
72 Short Step
Old 11-11-2011, 10:02 PM   #10
chevytruckluver
ttt
Trey
72 Short Step
Old 11-12-2011, 09:04 AM   #11
hgs_notes
GEARHEAD
hgs_notes's Avatar
In order to convert to power brakes the rod between the pedal and booster must also be swapped. They have different ends on them, but are not that hard to find at a junkyard.
hgs_notes is offline   Reply With Quote
Old 11-12-2011, 09:40 AM   #12
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Still available??. shipping to 29708
TobyArnot is offline   Reply With Quote
Old 11-12-2011, 09:54 AM   #13
chevytruckluver
I still have it. I will get you a price, just a quick guess I would say 20.00
To be quick and easy I will do 100 shipped to you, if it is a few dollars more then I will cover it.
Trey
72 Short Step
Old 11-14-2011, 06:13 PM   #14
nevets
if you still have the setup i am in the Houston/Huffman area...
nevets is offline   Reply With Quote
Old 11-15-2011, 12:27 AM   #15
chevytruckluver
At this point no one has said "I'll take it" so I still have it
Trey
72 Short Step
Old 11-15-2011, 10:11 PM   #16
kamikazekyle05
kamikazekyle05's Avatar
Ill take it, pm me your paypal address
kamikazekyle05 is offline   Reply With Quote
Old 11-15-2011, 10:41 PM   #17
chevytruckluver
Sold to kamikazekyle...pm sent
Trey
72 Short Step
