Old 10-19-2011, 03:03 PM   #1
chilihed
exhaust system recommendations
I have a 1970 LWB with a 350. It still has the stock manifolds, and is missing exhaust pipe from muffler back. I would like to find something not too expensive that would bolt right in without having clearance issues. If that means I keep the stock manifold then so be it, but I am not opposed to long tubes if they clear. I need the system to be dual exhaust and I don't care if it is rear or side exit. It can't hang too low since I just finished a 3/5" drop. Stainless, or aluminized, or coated any of the above, just don't want it to rust. I have access to a welder so a kit is not out of the question. I would just rather not spend a week piecing, cutting fitting the dang thing together. Would like to be able to complete in a day by myself.
Okay there ya have it. Any suggestions are welcomed.
chilihed is offline   Reply With Quote
Old 10-19-2011, 03:17 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: exhaust system recommendations
For an exhuast system that fits,has good sound and you don't have to piece it together,I suggest a local muffler shop.They will bend to fit,weld it up and exit it anywhere you like.They may not be able to do one that will never rust but the price will usually be close to the cost of a kit without you having to do the labor or live with the downtime.Most will let you order the mufflers you want or have equivalents in stock.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-19-2011, 06:27 PM   #3
big mike71
big mike71's Avatar
Go to Budget Muffler on 23rd street in Independence, Mo. He will run it any way you want. Mine was $400.00 from the headers to the bumper with 2 1/2" exhaust, H-pipe and flowmasters.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 10-19-2011, 08:16 PM   #4
70-Chevy
-Chris
70-Chevy's Avatar
Summit has kits that you can buy and do yourself.
Dont know if this link will work, but you can search for yourself by entering make and model.
http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 10-19-2011, 08:17 PM   #5
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Good advise. I recently removed some old, rusty four tubes and ancient glasspacks. Went back to OEM cast irons. Had a local shop build, well, pretty much (above). Sorry for "W-I-P" pictures. (pic 1) Ran tubes back from front , over trailing arms, and a couple of well-placed bends over the rear and Panhard Bar. Back to a pair of, believe or not, Thrush Turbo's(pic 2). Added a pair of 3" x 12" angle-cut chromies and done. With the mufflers at the back, the cab exhaust noise is greatly reduced.
But, then again, "to each his own". That's one of the things that makes this so much fun!
TobyArnot is offline   Reply With Quote
Old 10-19-2011, 11:46 PM   #6
bruin_d
bruin_d's Avatar
I have a Suburban that lays frame. You said you weren't against side exit. Its 2.5" the entire way. Here's a few pics of what I did...
bruin_d is offline   Reply With Quote
Old 10-21-2011, 11:01 AM   #7
chilihed
Nice job on that burb!
Old 10-21-2011, 12:05 PM   #8
bruin_d
bruin_d's Avatar
Originally Posted by chilihed View Post
nice job on that burb!
thanks!!!
Old 10-21-2011, 01:47 PM   #9
kcsa75
kcsa75's Avatar
If you want to save a trip to Independence, there's also a Budget Muffler at 87th and Grant in Overland Park -- down the street from the library. I've never used them, but they seem to be busy every time I drive by.
How it's going Mike? Back to work yet?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-21-2011, 01:53 PM   #10
big mike71
big mike71's Avatar
Not bad Bill, I go back to the doc Nov 3rd we'll see what happens. The budget muffler in Indep. Has done all my cars he good and stands by his work.
Old 10-21-2011, 02:16 PM   #11
bollybib
bollybib's Avatar
I installed a kit recently but it took forever (and needed field bending and cutting, too). Best advice is take it to a shop.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
