Old 10-19-2011, 07:47 PM   #1
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
85 K30 7.3L diesel swap
well I figure I'd start a thread for my 85 K30 Crew cab, I'm currently trying to finish accumulating the rest of the parts to swap a 7.3L International Diesel and a SM465 backed by a NP205 into I'm planning on taking lots of pictures and do a full write up on it and as long as Photo bucket starts cooperating I'll have pics posted shortly
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
Old 10-19-2011, 08:22 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 85 K30 7.3L diesel swap
Very cool swap! I had a 6.9 in my 76 years back. Have you got the parts to get the 7.3 hooked to the SM465? I have a bell housing from a 6.9 4 speed that should work for you.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-19-2011, 08:27 PM   #3
Tex_50613
Tex_50613's Avatar
hadn't found a Bell housing yet and just got the price quote from Clutch Masters in Waterloo for a full ceramic clutch and new flywheel earlier todayso that would be awesome Dieselwrencher
Old 10-20-2011, 02:31 AM   #4
Dieselwrencher
Um, I can get you a clutch made that will be far better than a clutch master clutch. Dude, I bet I could get you a DD made as well. It might take a little time due to getting the fly wheel made, but it would be a billet sfi clutch and be bullet proof. Or, I can even get a hard core single disc made. I'll dig out that bell housing in the morning and take some pics of it for ya big guy.
Ryan
Old 10-20-2011, 10:41 AM   #5
Edahall
This is an awesome build. The International 7.3L is an example of how the GM 6.2/6.5L should have been built from the beginning.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-20-2011, 01:59 PM   #6
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
True, but they were also built for different purposes and designed very differently from each other. The GM 6.2/6.5 look like a v8 gasser, and the 6.9/7.3 look like a purpose-built diesel. I've torn them both apart and worked with them both in separate applications. I like the 6.9/7.3 better, but no one can convince me that the 6.2 is a piece of crap like everyone says it is.
Now... with that being said... I would LOVE to see a 7.3 in an old square body. Just remember the SCA additives in the radiator so it doesn't cavitate!!
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 10-20-2011, 02:17 PM   #7
Tex_50613
Tex_50613's Avatar
the what in radiator so it don't do what? I'm just a farmer here and that sounded greek to me, T was planning on antifreeze from the IH AG dealer locally
Old 10-20-2011, 03:43 PM   #8
Dieselwrencher
The 7.3's had a casting problem that over time, rust and corrosion would eat away at the block water jackets and create pin holes in the cylinder walls allowing coolant in the cyliners causing sever damage. Not all have this problem. I mainly have heard this from the early powerstrokes more than the IDI's. SCA is supplemental coolant additives and you can get it at your local parts store or a big truck shop. My favorite is Penray brand. You don't need much to protect your coolant system. Don't over due it, read the bottle and add the amount it says per the amount of coolant your system holds.
Ryan
Old 10-20-2011, 03:49 PM   #9
Dieselwrencher
Ok, I found the bell housing for ya.
Also, I have something that could be an option for you as well. I have 2 diesel 5 speed ZF 2wd transmissions and a divorced rh drop NP205. That'd be a cheap way to get the 7.3 in your truck buddy. Use a stock clutch for the IDI and be rolling. I may even have a stock fly wheel laying around but you may want to upgrade that any way. The 7.3's had a dual mass fly wheel and they usually are worn out or rattler like a SOB because they're loose as heck.
Ryan
Old 10-21-2011, 09:05 AM   #10
lindstromjd
Hmm... I've never heard of cavitating from the PSD's, but I do a lot more reading/lurking with the IDI's than anything. So I guess it's possible. I just know you have to be careful with them and make sure you have the additives in the coolant. If you go to the IH dealer though, they will have the proper coolant to put in it and you shouldn't have any problems at all.
Dieselwrencher, you say you have a divorced RH drop NP205? If Tex doesn't want to go that route, I'd definitely want to talk to you about it. I'm from Ankeny, and my brother still lives in WDM. I'll be driving up that way over Thanksgiving, too.
-357 / 700r4
-350 / TH350
Old 10-21-2011, 12:57 PM   #11
Tex_50613
Tex_50613's Avatar
gave Dieselwrencher a call and think I'll be using the 5 speed and the devorced to make life easer
Old 10-25-2011, 12:01 PM   #12
Tex_50613
Tex_50613's Avatar
some of my pics now
Old 10-25-2011, 04:15 PM   #13
Dieselwrencher
That's a great truck to start with!
Ryan
Old 10-25-2011, 06:37 PM   #14
Tex_50613
Tex_50613's Avatar
thanks, I wish the cab was in better shape but I may have another from a 2wd CC DRW lined up to use on this frame which will be easy to swap while I have the cab off to finalize the drive train locations on the chassis and was planning on a 2" body lift to ease with some clearances if need be although if I do have to install the body lift I will make it very hard to tell I did so and the truck ought to look sweet with a pair of my bumpers on it.
Old 10-25-2011, 10:24 PM   #15
andrewmp6
Is it the turbo or none turbo idi 7.3 ?
andrewmp6 is offline   Reply With Quote
Old 10-25-2011, 10:58 PM   #16
Tex_50613
Tex_50613's Avatar
non turbo idi but i may have a line on a banks sidewinder kit for it if i want it eventually
Old 10-25-2011, 11:06 PM   #17
Dieselwrencher
If it's the small non waste gated turbo kit you should be okay. If it's the bigger one, you better be careful. These IDI's need bigger wrist pins to take much boost over 7psi. Ask me how I know.
Ryan
Old 10-26-2011, 01:12 AM   #18
andrewmp6
The idi are good for a normal diesel they ain't fast but run forever and pull anything.I had one in a 92 f250 was a old work truck had over 300k on it still ran prefect tell the auto trans died 2 years later.
Old 10-26-2011, 10:07 AM   #19
Tex_50613
Tex_50613's Avatar
this one is out of a 93 F250 4x4 auto and the trans puked it it too, has somewhere around 314k on it, but till it fits in the truck properly I'm not gonna tear it down but eventually I'll freshen it up with with rings and bearings, but for now it's a swap and run kinda idea
Old 10-26-2011, 05:26 PM   #20
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Nice looking truck to start with looks like its in pretty good shape. Going to be pretty badass when its done. Can't wait to see some progress and pictures good luck with build
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-26-2011, 06:23 PM   #21
Tex_50613
Tex_50613's Avatar
it needs help, here's the drivers (lack there of) floorboard,
the truck needs some TLC for sure, being as it was a old farm truck and had a plow on it
Old 10-26-2011, 08:29 PM   #22
Dieselwrencher
You guys got rain? What's that like?
Ryan
Old 10-26-2011, 09:00 PM   #23
Tex_50613
Tex_50613's Avatar
that was like May or June
Old 10-26-2011, 09:09 PM   #24
Dieselwrencher
I see.
Ryan
Old 10-27-2011, 07:22 AM   #25
andrewmp6
Yeah diesel swaps can be fun or a pain i have helped with two so far.One was a 12 valve in a k5 blazer the other was a 7.3 turbo from a school bus in to a super duty with a blown engine.One day i will build a 12 valve square body or maybe a 90s f250 just gotta get the cash up first.
