What type of adhesive do you use on the Door weather seals?
Im ready to put my door seals in but not sure what I should use to hold it in place?
#16876
Re: What type of adhesive do you use on the Door weather seals?
3M works for me.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
3M weatherstrip adhesive is the best, comes in yellow or black also known as "gorilla snot"
Active Member
![]() Join Date: Jul 2007
I bought the push on style from GMC Paul's. So far has worked great and didn't have to use any adhesive.
Good luck.
I did put new door seals from classic industries and never were sticked well. 3M yes is good but finally I did put one from Dodge Dakota and don't need any glue. |
![]() Join Date: May 2011
Active Member
No. They don't look original. If you're looking to keep it orginal you have to get the glued on type. I have a new set of the original type but didn't like to have to mess with the glue since I want to paint it inside and out sometime in the future.
Pics. |
The 3-M weatherstrip ad. works good. Use the black. It looks OK if a little oozes out the edge. The yellow looks bad. Get a fresh tube. When its stale it is hard to spread.
if youre going 100% original then have fun with the glue stuff ... but the push on seals are so much nicer and soooooo much easier to deal with....
needs more $$$
Do the dodge's work on blazers too?
1970 2wd Blazer |
What year dodge Dakota seals do you use?
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
I don't remember the year of the Dakota, probably 90's-95's.
I saw here in someones thread, and one day I saw a truck in a pick your part, they were in a good shape and I bougth them.They were cheap and I ran the risk they were'n fit but trust me |
#13 |
Florida Edition
![]() ![]() Join Date: Oct 2010
The trick to using 3M or similar is to run a small bead around the seal groove and a small bead around the fin on the cab.....smear both flat with a butter knife or whatever...and let them tack-up for a minute or two. Then put them in place. Start at the bottom center over the rocker and work your way up and around and then seal them up where they come together. You may have to trim the end when you get there but that's easy. Your sill plate hides the joint so don't worry how that part looks.
The key to this is run SMALL beads and don't wait too long or you will lose tack. Done right you won't need clamps or anything else. The sealant bonds to itself quickly. Thanks to the 3M rep on "My Classic Cars" TV show for this info!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#14 |
Moderator
![]() Join Date: May 2007
gmcpauls push on seals are the BEST. just look at the review board. a 5 year old can install them. they seal nice and tight and are way better than the original glue on seals in every way possible.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 |
Florida Edition
I just ordered a set from Paul for my 67 Slantback...since it's a King Rat looks won't matter. Gotta look original on my 70 build though. Thanks
#16 | |
Florida Edition
Got advice and or pics? Thanks Posted via Mobile Device
#17 |
![]() Join Date: Nov 2007
It will make the corner but it will be a bit rounded. I hit mine with a deadblow hammer (also a rubber mallet could be used) to get it to seat as much as possible.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#18 |
Florida Edition
Thanks webfoot....I think that if this is to be installed correctly it has to be wedge cut and resealed with black 3m...not exactly the job for a 5 year old. I'm not being negative but before shelling out $50 it would have been nice to know these need modified.
Don't get me wrong...I can do it but this is info that novices need to know up front. I will post this fix when I do it so others can learn but if someone has done this already I'd like to see some pics or get more input before I start. If the wedge is cut too big on the first try the seal is ruined. If Paul jig cut and sealed these it would be the best I've seen. Brad Posted via Mobile Device
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by RenoKeene; 10-24-2011 at 08:13 PM. |
#19 |
Florida Edition
I'll throw this out there....I would be willing to pay twice the price if these were profesionally fitted.
That would be about $100 a set. How about it Paul.... Posted via Mobile Device
#20 |
Do you think he is the only one that sells them? you guys should know better
#21 |
Florida Edition
Not sure what you're saying Mike...you know a supplier that sells these push-ons pre-mitered?
#22 |
Hi there, I just installed a set of these on my '66 and never realized they had to be modified. My door will close but it's super tight and doesn't stay 'flush' with the body. If you can...will you post pix of how I'm supposed to modify to resolve this issue.
Thank you!! |
