Old 10-19-2011, 10:42 PM   #1
lenguini
lenguini's Avatar
Want to hide windshield washer hoses
Greetings all..hope there are some builders out there that have some great ideas on how to move and hide washer hoses so that they no longer are visable in the engine compartment at the firewall.
All ideas and advise will be much appreciated.
Thanks in advance.
lenguini is offline   Reply With Quote
Old 10-20-2011, 11:27 AM   #2
jimmydean
jimmydean's Avatar
Re: Want to hide windshield washer hoses
I've been looking at this very issue. Just read through the electric washer pump conversion and was trying to find options.
I'll post pics if I come up with something. I'm sure it's been done.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-20-2011, 11:30 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
The only way I can see it is you`ll have to run your washer bottle in the cab and run your hoses thru the bulkhead into the cowl area.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-20-2011, 04:17 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
The view of my washer hoses are somewhat minimized, going through the driver side lip of the firewall flange, and running over to a pair of outlets in the center (shown in the circles). The aftermarket electric washer pump is mounted below the bottle on the driver side of the radiator support.
To completely hide the hoses, it would seem relatively easy to run the main line under the inner fender support (arrow) into the cab. From there run a line into the back of the dash/fresh air plenum and connect to the nozzles directly under the cowl vent.
Old 10-20-2011, 05:12 PM   #5
jimmydean
jimmydean's Avatar
That looks very clean. I was looking to do something like that.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 10-21-2011, 10:02 AM   #6
lenguini
lenguini's Avatar
Thank you for the advise,looks like a pretty good solution to me.
Cheers,
Ed.
