BIG CHEVY 3600 LONGBOX
Has anyone had experience
installing high beam and turn indicators into little holes in the dash? I bought the three LED lights and want drill the holes just above the two gauges on the dash. I know I won't have more than one chance to do it right. Does anyone have any suggestions on how to drill these little holes without screwing up my dash?
http://s729.photobucket.com/albums/w...t=PA180001.jpg
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: Has anyone had experience
I dont know if it's the right way but....
Take the dash out Clean the dash Lay out your holes on masking tape. If your tape is level, centered and square with the dash plate and the holes look right start drilling. Use smaller bits to start and go up. Oh yeah go slow, cuz you only have one shot at it. |
I always use a step drill bit. A regular one will drill a triangle hole in sheet metal almost every time.
what i do is take a felt tip and mark all the way around the step up from the one that I want. that way I don't lose count and drill too bib a hole. You can use a regular drill bit [no bigger than 1/8" for a pilot hole. Try it on a piece of scrap of the same thickness first to get the feel of it. P.S. they make smaller ones. hope this helps. mark |
Mark has all the fancy tools
#5 | |
LOL I did 20 years as a prototype machinist.
you can use a spring punch to make a indentation in the metal so your bit won't slip on ya
What is a spring punch?
BG 3600
a spring punch is a center punch that has a spring in it, so all you do is put the point on your metal surface and push down - it;ll put the indentation in the metal then spring bk . its about the size of a sharpie - harbor freight has em - so does home despot holla if ya need help |
A center punch that uses a spring and anvil inside.You mark where you want the hole and set the point of the punch where you want the center and push and "snap" automatic punch center for the drill bit.they are great for sheet metal.
If I were doing this I would first get thin card board (I use part of a 12 pack of pepsi box). Use the cardboard to make a template. This way you can use a ruler and get them all positioned and test hole sizes. When its exactly how you want it position the template on the dash with tape so its exactly how you want it. Since you know your hole sizes mark the holes with marker and then use a punch and a step drill (mentioned above). This way everything is perfect before you drill since you only get one try.
Oh and clear out all the wires behind the dash so you don't drill into them. You can't just simply remove the AD dash. Good Luck |
That part about removing all wires behind the dash so I won't drill into them is exactly what would happen if you hadn't warned me. lol
#13 |
all the above should put ya in the right direction and good luck !
#14 |
like this.
#15 | |
#16 | |
#17 |
A picture is worth a thousand words. Thanks for three thousand words.
#18 |
Yellow truck club
If the light ends up a little loose in the hole a dab of silicon on the backside will hold it.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#19 |
