6 lug to 5lug or not?
What if a person already has 6 lug drums like on my 69. What is the benefit of swapping to 5 lug if I were going to run 18's or 20's anyway?
I mean, I'm going to swap to disks but I can't find a definite answer as to why I need to go 5 lug? I klnow this has been covered a ton but I just kind find the reason why somebody would swap other than wheel size, backspacing, etc? Has to be a reason? Please school me... Thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 6 lug to 5lug or not?
Just personal preference.
I like 5 lug wheel "patterns/designs/styles" better. Most 6-lug aftermarket wheels are designed for the 99-up GM trucks. The backspacing is usually wrong for our trucks,... plus the center bore of the wheel is too small to bolt on these old trucks. Most "high dollar" billet wheels can be purchased in a 6-lug pattern. It's your choice. Convert the front to 6-lug disc. Or convert the rearend to 5-lug. It's all about the wheels YOU decide to use.
#3 | |
Thanks for the response Keith. I've read a lot of your stuff on this forum and value your opinion... ![]() I don't have a problem going to the 5 lug as it seems the price is about the same because I would buy all new spindles and such anyway. I was just curious as to why so many people do it cause I can't be the only one out there with a 69 that hadn't wondered the same thing? So, when I make the switch to 4 wheel disk 5 lug, what is the bolt pattern? Is it 5 x 5? Thanks again for the help and bearing with another newbie... |
Another question Keith,
I'm going with 2.5" spindles and 2" coils in the front and 4" coils with 2" block in the back. Could you narrow down a few possible senerios I have with backspacing and offset Please? Thanks |
#5 | |
ECE sells a 6" drop rear spring. I would use those to get a 6" rear drop. Yes, the 5-lug pattern is 5 x 5. What size wheels did you have in mind? Nate (72BlckButy) has 20x8.5 (5.5" BS) and 20x10 (4.75" BS) on his 69. It also has the original 69 rearend housing, which is narrower than the 71-72 rearend housings. So your rear wheel BS will depend on which ever rearend you use. (5-lug or 6-lug)
#6 | |
I have never seen Nate's truck so I'm not sure how it looks? If I keep the original 69 rear end housing how do I convert it to disk without buying new axle ends? Is it just as easy as taking of the drum and bolting on a disc? If so, I may stay with 6 lug as I'm sure I could find a 18" or 20" wheel 6 lug that I like. Please bear with me as I'm just learning all this so all I know is the stance I want which looks like a 4/6 drop or something close to that with a 18 or 20 wheel, wide tires and handle good. Other than that I'm at a loss of exactly what I need to do that. I found the grand slam kit from CPP that looked like what I would go with but I seem to get more confused the more I look at it. My 69 is also a fleetside if that matters for clearance issues? I'll try to find Nate's truck and see what it looks like while I await some more knowledge from you... Thanks for all the info and please be patient with this dummy that's typing... |
Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=353633 I keep the original 69 rear end housing how do I convert it to disk without buying new axle ends? Is it just as easy as taking of the drum and bolting on a disc? No. You will need to change axles or machine and re-drill your original axles. Then a disc brake kit will need to be purchased. I found the grand slam kit from CPP that looked like what I would go with but I seem to get more confused the more I look at it. I personally am a huge fan of CPP products,... but not their customer service. Look in the Suspension Marketplace for great suspension deals from the people that support this forum. These are major suspension companies that choose this board to sell/promote their products,... but they are also members here, just like you and me.
#8 | |
Junior Member
![]() On the wheels... I completely agree with Lowlife99... You will find a better selection of better looking wheels in 5 lug ![]() |
#9 | |
Tot Roddin'
![]() 5x5 is a far better option for wheel selection. I would have made the same choice had I not located a wheel that would accomodate the 6x5.5 pattern on a 5-spoke wheel.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
My front is from a '75 C10 and my rear is from a '94 Caprice cop car. Less than $300 for the front and rear, same 5x5 lug pattern and 4 wheel discs. I did it for wheel choice, too.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Hey I could always use some help Moderating the Suspension section.
Talk to Ken and maybe you can help me out! ![]() Seriously,... thanks for taking time to check in.
#12 | |
You're not in this alone buddy!
#13 | |
I appreciate your wealth of knowledge. (plus I was just taking a "jab" at Tony. Ha)
#14 | |
I found Nate's truck. It's AWESOME too!! Exactly what I want mine to look like... If I'm going to have to buy axles I may as well go 5 lug anyway. Looks like it will be comparable in price either 6 lug or 5 lug and at least I would have that huge selection of wheels. I may just give one of the forum supporters a call and talk with them on exactly what I need to buy? Do you recommend one over the other for a newbie like me with no knowedge? I will check the Suspension Marketplace right now and see what I can find. Thanks to all for the info, especially you Keith. SWEET truck Nate!!! ![]() |
#15 | |
Happy to be here
![]() Join Date: Mar 2000
#16 | |
What is the center bore on our trucks? I have found some 18's and 20's with a 78 and 108 diameter? Will these work or will I need to have the bore machined? Thanks |
#17 | |
The wheels I'm looking at are Enkei RT6. Sorry I don't know how to post the link or pic but if you could give them a look and tell me your thoughts? Thanks |
#18 | |
Tot Roddin'
Thanks buddy! Now I can't speak for the 5-lug bore, but I ordered my Vintec's with the following specs: Billet Specialties Vintec's Front: 20x8.5" w/ 5.5" BS - Center Bore: 3.430 - Bolt Pattern: 6 on 5.5" Rear: 20x10" w/ 4.75" BS - Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43]) - Bolt Pattern: 6 on 5.5" Toyo Proxes S/T ii's Front: 255/40-20 Rear: 295/40-20 The BS bores were to close for me to order the wrong size so I went with these and ran into zero issues on the mounting. Let me know if you have any additional questions; more than willing to help you out.
#19 | |
#20 |
Tot Roddin'
Nah.... you, lolife99 and n2billet. (At least from my perspective).
![]() Thanks Scoti; much appreciated.
#21 | |
Thanks Nate for the info.. This is exactly what I was needing. Did you or anybody else have time to take a look at those Enkei wheels I mentioned? Looks like those bore #'s were in millimeters so the 108mm should be the 4.25 that I need. They also offer them with +12 offset and 0 so I should be good there as well correct? I'm going to save your info so when I go get tires and such I will have a GREAT reference!!! Thanks again for all the help... ![]() |
#22 | |
This will work up front. The rear might require you to run a spacer.
#23 | |
I'm having an awful time finding wheels that are REASONABLE in price and different from all the torque thrust styles... ![]() |
#24 | |
Another perspective too.... The reason 5-spoke wheels are not 'different' is because they compliment the classic looks of older cars/trucks. Sometimes bolting something 'different' on just to avoid what's 'common' works against you. I like wheels that are symmetrical. The wheels you have listed have 6-spokes w/5-lugs causing the spacing of each lug hole to be different within each spoke. This is a definite no-can-do in my book. Traditional/common wheels work just like OE paint jobs vs the current trendy paint schemes (think mono-chromatic w/graphics during the late 80's). Consider this before spending your money. If you're set on your current choice, they'll fit.
#25 | |
Thanks SCOTI.. never really thought about it in that way. I always have been one to go for a different look when customizing my trucks BUT, it has been on newer trucks as well so I guess that is where my problems begin? I don't have anything against the torque thrust wheels, I actually think they look awesome on our trucks, but EVERYBODY has them...I guess you have made me understand why now... ![]() Guess I'll quit bucking the norm and look for a more traditional style thrust wheel. Is it possible to use the same 4 wheels with the same BS and offset on all 4 corners or do I need to order a split set with 2 different offsets and BS? Seems most people have 2 different specs for front and rear and I also assume this is for a reason as well? Thanks for letting me drive you guys crazy with questions, I just don't know what I'm doing.... ![]() |
