10-20-2011, 09:59 AM | #1 |
Artist
Hacked up doors!!
So the PO decide to cut my nice solid doors for a set of old, huge, horrible 6x9 speakers.... If I could find him Id "tie him to the car... and drag him". SOOOOOOO does anyone have a set of doors that are uncut at the bottom that maybe the rest of the door is junk, and your willing to cut up?
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
10-20-2011, 10:03 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Hacked up doors!!
I do but not near you, sorry
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-20-2011, 10:07 AM | #3 |
x-2, but I did pick up a set of junk doors for free...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
10-20-2011, 10:08 AM | #4 |
Artist
Cut and ship?? :-)
10-20-2011, 07:28 PM | #5 |
i have some that i was trying to sell but decided to gut them and cut them up. i can cut the inside out if you want and ship them.take a better picture so i can see how much you need.
10-20-2011, 09:01 PM | #6 |
Why not repair what you've got? Cut out a piece of metal the same size and weld them in, not a big deal. A bit of grinding and some body work and you can save what you have. They look like a good set of doors, the set you get may need work also.
10-20-2011, 10:56 PM | #7 |
I might have at least one side for ya. Ill check in a few when I go to the garage to keep working.. Daytona is cominng quick!!
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
10-21-2011, 11:24 AM | #8 |
meowMEOWmeowMEOW
It seems like 60% of these got the doors cut like that. I know mine did. My solution is a little different; dynamat the door and put a better speaker in.
10-21-2011, 11:52 AM | #9 |
But Found Her 25yrs Later!
Yes, very common.
That's why anyone who has junk doors, before they scrap them, should cut that area out if its still intact. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-21-2011, 01:01 PM | #10 |
Artist
LostMy65 EXACTLY RIGHT!! I want to "Look" bone stock at first glance (minus the lowering). Speakers in the doors kill me!
10-22-2011, 01:14 AM | #11 |
I looked at one of the doors I have and the area that you need is fine and no one cut it for speakers. I didnt check the second door yet but like I said, If at least one patch can help I will cut it out and send it to you??
10-22-2011, 06:07 AM | #12 |
LMC truck and several other places sell repair or patch panels for the inside of the doors too- it's a lot less work than prepping used ones. JMO
10-22-2011, 06:17 AM | #13 |
I have some rotted doors I could cut out. Is it just a flat piece? Welding is going to be hard without warping that panel. I have used polyuerathane adhesive on panel but metal has to be ground clean. email me
10-22-2011, 12:16 PM | #14 |
meowMEOWmeowMEOW
^^buy a copper block or welding spoon. Helps channel the heat and really helps with burn and warpage on sheetmetal. I haven't tackled my inside yet, but for doing the door exterior it was a lifesaver.
