Chris
rally wheel cap and ring questions
Just saw the thread about the centers and the plastic ones being junk, which is a shame, because it's what I'd end up using I bet, thing is I was looking at lmc and they have a cheap set, but 2 have the holes for the front, ok I plan to run some on my 88 which is IFS so no need for front holes.
Can you buy the insert to put in the front 2? if so where? the ones lmc has? Can you get custom emblems like a bowtie or something instead of the 4x4 one? If so where. Next up would be where is the CHEAPEST place to get some centers and trim rings, I want wide 3 inch trim rings, and I done checked like ebay, lmc, summit, and amazon. So far ebay has a $60 set of no hole 4 centers with bolts, lmc has a cheaper set at around $45 but front two have the holes, trim rings was ebay for $60 for 4 chrome 3 inch wide ones. Junkyards are out of the question, none around here. Also, anyone tried to 16 inch ones from the gmt400 trucks the 6 lug ones? Or has anyone tried the corvette/camaro style? I see lmc sells them and was told I could run them just not sure.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
| Bookmarks |
