![]() Join Date: Aug 2010
Ok guys. This has probably been talked about or shown before, but I wanna know the cheapest way to drop my truck down. I'm not talking slamming, or laying on the ground. I just wanna get the rear down for sure, and maybe the front. Maybe 2-3 inches in rear. Probably only 1-2 in front. After putting my vintage AR turbines on and Cooper Cobra Radial G/T's in 255-60-15 it really showed how bad the rear stuck up in the air.
Someone told me something about blocks in the rear and cutting thier front coil. Please enlighten me on what to get, what to do, and how to do these things. Pics would be most appreciated! ![]() Here's some pics so you can see how my truck sits. Oh, and the PO installed rear coil over shocks, which just changing those out I would think might help some. Rear end shot, you can see the coil overs.
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
C/10 junkie
Re: Cheap Drop HELP!
Cut one coil off the front, will give you roughly 2" and some used A-body springs out back, ie Chevelle etc. I have set of Chevelle springs that came with my truck when I bought it and they were good for about a 3" drop. Since I have installed 5" truck springs with 1" blocks out back to get it lower.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
C/10 junkie
Here is a pic with 1 1/2 coils cut off the front and the Chevelle springs in the rear.
C/10 junkie
And here is with the new wheels and tires and 5" rear springs and 1" inch blocks. Front tires are 245/60r15 and the rear are 255/70r15. In the first picture all tires were 235/75r15
Thanks. But how much would it cost for a set of chevelle springs? Would it make the ride too bouncy or soft? Cutting the front springs sounds like the way to go there, but how do you get them out and it? Never done that before, not that I don't have basic mechanical skills though. What about rear blocks? How does that work? Sorry for all the questions, just wanna do this cheap and right. Did you need shorter shocks anywhere?
C/10 junkie
The Chevelle springs will make the ride nice and soft but you cant haul much. I run the stock shocks up front and ran stock out back with the chevelle springs. You can have mine if you want. Just pay shipping.
On the main forums section of this site, there's a sub-section titled 'FAQ'....
http://67-72chevytrucks.com/vboard/f...splay.php?f=92 Look through the FAQ/truck tech for suspension info. If you can't find what you want there, here's more info that was organized by one of the long-time members (also found within that FAQ section).... http://67-72chevytrucks.com/vboard/s...d.php?t=262547 Look through the suspension stuff & there's several budget 'how to's' for lowering. There's one for making your own lowering blocks, modifying the shock brackets for better travel, etc....
Well, this definately isn't gonna be a hauler (like the PO used it for). It's gonna be a cruiser/show truck in the end. How much would shipping be on those to 40353?
#9 | |
#10 | |
C/10 junkie
So they won't require any modification? Just swap 'em out? Right? If so interested. Feel free to PM me with exact quote, paypal, etc. Is that USPS Parcel Post?
C/10 junkie
Yes they will swap right in, no modifications at all. Took me about 45 minutes to an hour to change. I will box up tonight and pm you a total, and yes that was parcel post. If you want priority let me know.
#13 |
C/10 junkie
Hey I haven't forgot about you, just had some things come up this weekend, sorry about the delay. I am headed down to the post office this morning to get you a qoute.
#14 |
C/10 junkie
Sent you a pm with pp info and price.
#15 |
C/10 junkie
Did you get them in yet? Lets see some pics if you did.
#16 |
Maybe this weekend!
#17 |
Let's see it....
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#18 |
Grandpa in the rustmobile...
If your not happy with chevelle springs/jeep springs whatever (i ran jeep springs, they worked but there WAYY to soft for a truck) you could go with a 2" drop block and if you wanted the rake back cut a coil
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#19 |
Where to get, how to do, and how much on drop blocks?
#20 |
67-72 parts collector,…
![]() Join Date: Nov 2002
With 15" wheels you can use up to a 1.5" drop block.
Member way2lo2 sells them in the suspension marketplace. Drop truck springs are really the answer. But these require a drop shock also. Look at other members trucks and try to duplicate the drop you like. Just remember that a 2 inch drop rear spring is compared to a stock height NEW spring. Not a sagging 40+ year old spring. Suspension and brakes should be a priority. Do it right the first time. Posted via Mobile Device
#21 |
listen to keith he is the man
#22 |
Thanks guys. Gonna try the chevelle springs today since I got them. The PO has new coil over shocks and new heavy duty rear springs (maybe for a C20?). So the current set up is extremely stiff! I'm also gonna go buy some new stock ride shocks. Hoping this will soften up the ride and give me some drop so Copper's butt isn't sticking up in the air so much!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 Last edited by slick copper; 11-06-2011 at 01:01 PM. Reason: color |
#23 |
C/10 junkie
Can't wait to see how it looks.
#24 |
Alright! They're in! But......because of the previous set up (VERY stiff) It actually gave me a 5" drop!!!
![]() ![]() ![]() From 34" To a little below 29" Ones I put in..... Ones I took out!
#25 |
Here's pics of Copper's stance now. I love the way the rear looks now, but going to have to drop the front about 2 inches. The rear is at 29" the front is at 31". Thinking of putting the coilover shocks back in to see if it'll raise it up in the rear some.
