10-20-2011, 06:20 PM | #1 |
PS Pump Removal
Can the PS pump be removed without also removing the brackets on a 1970 chevy?
Here's what I did so maybe someone can tell me what I'm missing: I removed three nuts that hold the pump to the brackets. One that fits through the slotted adjustment part of the bracket. One nut that fit in a slot in the back of the bracket. And one nut at the bottom front of the bracket. I also removed the belt from the pulley. The pump will rotate, but will not come out. Any suggestions?? |
10-20-2011, 06:44 PM | #2 | |
Re: PS Pump Removal
69 Chevy 4x4 383 Power |
10-20-2011, 09:15 PM | #3 |
I am a Referee of life.
Re: PS Pump Removal
The Bracket that pivots.Needs to come out.It cradles the pumpand the pump bolts to it.The two bolts(front and rear) need to come out.Then the pump with that bracket will come out.You can then remove the pump.Take the Hoses off before you do any of it though as it is hard to hold the pump still while trying to loosen them.
Once the bracket piece and pump are out the pump will swivel out of that bracket.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-21-2011, 01:45 AM | #4 |
~Rest In Peace~
Re: PS Pump Removal
take pictures before removing so you can see how it goes back ,just sayin
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
10-21-2011, 12:02 PM | #5 |
Re: PS Pump Removal
Thanks guys. I ended up taking the pump out along with the bottom bracket. Then played hell getting it all bolted back up. But a few choice words and some blood sacrifice and she's all done.
