Old 10-20-2011, 08:04 PM   #1
ky_kid
ky_kid's Avatar
Parking brake adjustment
I got the light to work but the brake doesn't grab. The brake was serviced recently so I think it's fine inside the drum. The cable under the cab has a lot of play and can flop around. I've read about a bolt/nut to tighten the cable but I'm not seeing it. Can someone tell me what I'm looking for?
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 10-20-2011, 08:09 PM   #2
Rogue_Alphonse
Rogue_Alphonse's Avatar
Re: Parking brake adjustment
The nut/bolt is where [on 1982? and up] the two rear cables from the drums meet together, about 2 feet from the rear axle on the driver's side.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-20-2011, 08:12 PM   #3
ky_kid
ky_kid's Avatar
I see what you mean I think. Has a bracket with one cable that becomes two...
Old 10-20-2011, 08:17 PM   #4
Rogue_Alphonse
Yep. The end with one cable going into it should be threaded with a nut on it. Just give it a good tighten. 1/2" wratcheting wrench works wonders!
Old 10-20-2011, 09:22 PM   #5
ky_kid
ky_kid's Avatar
Tightened it up and it's good to go.
Thanks!
Old 10-21-2011, 12:13 AM   #6
Rogue_Alphonse
no probs!
