Old 10-20-2011, 08:59 PM   #1
dalfy1505
top question
i finaly finished the drivetrain on my 73 jimmy im gonna start the body work now i decided on a rootbeer brown body with a black top. question is i cant decide how to finish the top linex or rhino line and paint i want it to last a long time so please give me your opinions or any other suggestions will be much apreciated thank you
dalfy1505 is offline   Reply With Quote
Old 10-20-2011, 09:00 PM   #2
Rogue_Alphonse
Rogue_Alphonse's Avatar
Re: top question
You shouldn't need to do anything like that to the top, it's fiberglass.
I'd give it a glosscoat if anything!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-20-2011, 09:35 PM   #3
dalfy1505
Re: top question
thanks as you can tell i have no clue how to take care of fiberglass so i will check into that
Old 11-03-2011, 11:07 PM   #4
4pilgrim4
Re: top question
The fiberglass top on my 82 Jimmy had paint over the fiberglass. The paint had sort of a 'sand finish' similar to anti-skid used on some fiberglass boat decks, but with much less sand.
When I repainted the vehicle several years ago, I removed the fiberglass top, placed it on some sawhorses and stripped all the old paint off. The bulk was removed using a 1/4 sheet electric sander. The final sanding was done with a 'long board'. Once prepped, I shot the whole truck with 2-part polyurethane enamel and followed directly with a clear coat.
At first it seemed a little strange to have a smooth, shiny top rather than the sand finish. But now I really prefer it that way.
4pilgrim4 is offline   Reply With Quote
