Is there a name for the washer that's behind the wheel cylinder bolt?
![]() Had to pry off one end to remove the bolt. |
The Older Generation
Re: 70 front drum brake part question
It's a locking washer. I'm not sure if they are available or not. You might try taking it to your Chevy dealer if you have one in your area. I know it doesn't look the best but you can actually reuse it. Just bend one of the good areas up against the bolt after you get it tightened up. You may have to make one. LockDoc
It's pretty much toast. There should be another tab facing the other direction. Thanks tho
