Old 10-20-2011, 10:19 PM   #1
68350
68350's Avatar
402 just not running right(frustrated)...
Ok, I guess I'll start off with what the engine is...
1970 402 truck block
1965-1967 396 car heads
1970 BB truck quadrajet rebuilt
HEI with aftermarket cap
rest unknown but all looked good when engine had new gasket set installed
Timing is set at 12 below TDC
Idle set at roughly 700 in park
Ok, here are my issues. It doesn't seem to want to run worth a crap when you put it in gear. By this I mean it has a slight stutter if you gas it after its in gear. It will rev up in PARK perfectly fine. If you get on it, it has alright power(nothing like my other big block truck) until about 2000-2500 RPMs, then it feels like it loses almost all of its power until it shifts, then it regains a decent amount of power. The truck has a 4.11 rearend, so I would think it should have way more snap than my 68 which has a 402/400/3.08 rearend.
Can anyone shed some light as to where to start. Also, can anyone tell me how to properly set mixture screws on the q-jet? What should the idle be at in gear, too? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-20-2011, 10:27 PM   #2
hugger6933
Re: 402 just not running right(frustrated)...
Big blocks love timing give it some more and try agian. Try to go" all in " and set up about 34-36 @ 3000.
hugger6933 is offline   Reply With Quote
Old 10-20-2011, 10:32 PM   #3
Lee H
Lee H's Avatar
What is below TDC? Did you mean before or after?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-20-2011, 10:35 PM   #4
68350
68350's Avatar
Sorry, before
Old 10-20-2011, 10:36 PM   #5
68350
68350's Avatar
At first, it was about 18 before at idle, and it acted basically the same as far as losing power above 2-2500
Old 10-20-2011, 10:59 PM   #6
Autoblueprint
Autoblueprint's Avatar
Lightbulb Re: 402 just not running right(frustrated)...
Put a vacuum gauge on your engine and see what your readings are:
http://67-72chevytrucks.com/vboard/s...37#post4688437
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 10-21-2011, 07:18 AM   #7
into69z
"brand new second-hand"
into69z's Avatar
i had a similar problem and it was due to the vacuum advance unit from the distributor was hooked up to the wrong port on the carb. I am dealing with an eldelbrock carb, it has one port for non-emission control vacuum and one for regular ported vacuum. The motor was set at 18 degrees btdc and would stumble at around 3000 rpm-switched the vacuum line and all is good. check the book on the ports for your carb-could be similar
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 10-21-2011, 06:56 PM   #8
68Gold/white
It seems like you have a vacuum leak. Plug off the PCV, and vac advance one at a time to make sure one isn't leaking.
Make sure the carb base gasket is sealing, is it new??? or used??? Ive re-used base gasket several times, but they quit making a seal, when you least likely need them to...
Idle RPM, depends on your cam. A stocker or mild cam could/should be around 750 RPM in gear, w/ vac advance plugged.
TO set the idle screws (w/ vac advance plugged), screw one in, until the engine starts to NOT to run smooth, then back it out 1/4 turn. Then do the other. Takes a little time...
IF you have an aluminum intake, The intake bolts need to be retorqued several times (only re torque them when the engine is stone cold) keep checking them until they don't loosen up any more...
68Gold/white is offline   Reply With Quote
Old 10-21-2011, 07:23 PM   #9
SOON2BLAZE
SOON2BLAZE's Avatar
My BBC is at 44 BTDC and pulls 17-18" of vacuum, idle is 750-800 rpm's if this helps
SOON2BLAZE is offline   Reply With Quote
Old 10-21-2011, 07:49 PM   #10
69sixpackbee
I run my 402 at 16BTDC and limit the total centrifugal to 10. Runs like a scalded cat!
69sixpackbee is offline   Reply With Quote
Old 10-21-2011, 07:49 PM   #11
69sixpackbee
??? ya mean 14 I hope
Old 10-21-2011, 08:18 PM   #12
SOON2BLAZE
SOON2BLAZE's Avatar
doooh!
Old 10-21-2011, 09:06 PM   #13
68350
68350's Avatar
Well, I definetly had my fair share of dumb moments last night. I forgot to plug the vacuum advance while timing it, redid it and it maxes out at 6 before. So I am going to pull the distributor tomorrow and move it over a tooth so I can retard it a little more. I will let everyone know if it solves my issues. I checked vacuum and its dang near perfect.
Old 10-21-2011, 09:22 PM   #14
Lee H
Lee H's Avatar
While dist is out make sure the shaft and mechanicals are free and well lubed. Springs should be light and easy to advance.
Old 10-21-2011, 09:30 PM   #15
jtp67-72
jtp67-72's Avatar
Not retard it--advance it..............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 10-22-2011, 11:04 AM   #16
68350
68350's Avatar
Well my other BB runs amazingly at 14 before, so thats where I'm going with this one.
Old 10-22-2011, 02:59 PM   #17
jtp67-72
jtp67-72's Avatar
going from 6 to 14 will do wonders --and that is advancing it........jim
Old 10-22-2011, 09:30 PM   #18
68350
68350's Avatar
Ok, I get what ya mean by advancing it. It seems to run a lot better but still not up to snuff so I'm gonna have my uncle look at it tomorrow and tune the carb and timing. He is pretty amazing at it so I'm hoping all goes well.
Old 10-22-2011, 09:37 PM   #19
jtp67-72
jtp67-72's Avatar
you'll never have a bigger grin on your face than when driving a c10 with a good running big-block!!!!!!.............lol..........jim (well maybe when u see what LSU did to Auburn!)
